Topic: Has anyone built a 40hp engine?  (Read 4361 times)
« on: April 18, 2014, 10:42:35 PM »
So I dragged a 40 horse long block that I've been tripping over to BAP, but no one was interested. When I was putting it back in its spot, I thought, why don't I clean it up and put it back together to have as a small runner in case I come across something that needs and engine!
So I have a long block, I have 3 extra heads, I have an intake. I have an oil cooler that could probably be cleaned out. What kind of things should I be looking for that are significantly different from a 1500? Are the cylinder tins different? Fuel pump? I think the exhaust is different (different width). Can I put a 12v flywheel on it? Are the rockers different? What about the push rods?
Any other tricks I need to watch out for? I have a gasket kit coming with new push rod tubs.
Re: Has anyone built a 40hp engine?
« Reply #1 on: April 18, 2014, 11:13:20 PM »
Over all nick, I think the 40 hp engine is narrower than a 1500. I think the doghouses are interchangeable, but I am unsure about the other cyl tin and head tins...
« Reply #2 on: April 19, 2014, 01:42:27 AM »
Yeah, I've noticed the narrowness. The intakes come in at right angles and the ports are flat vs the regular single ports, which come in at a slight angle. I've also noticed that the exhausts are more narrow too. I am pretty certain I have the right doghouse but I'm still curious about head tin etc.
Looks like the fuel pump is the same. I can put a later generator and stand on it. Rockers I haven't researched yet.
« Reply #3 on: April 19, 2014, 08:32:20 PM »
Nick, talk to Anthony . . . Formula V runs 40 Horse engines.  He'll probably know as much about them as anyone around.
« Reply #4 on: June 09, 2014, 04:32:03 PM »
Right. most of the tin is different, esp. the front and back pieces that have to line up with the exhaust ports, which are closer left-to-right than the bigger engines. The fuel pump would be the same. Intake manifold, of course, is shorter left-to-right. I think rocker arms are different. I know the pushrods and tubes are shorter. I think the later flywheel fits.
« Last Edit: June 09, 2014, 04:35:24 PM by Anthony »
