Topic: Green light - Red light on - When engine is running  (Read 2406 times)
Offline eakanator
  • Rome, Ga
« on: May 13, 2004, 10:09:02 PM »
As I mentioned, got the old bug we'll call her "Volksie" for now.
running this evening after sitting for 15 years. as I let it idle, little white smoke, well maybe moderate when giving it some gas was coming out  the exhaust ( better than black? maybe to lean) , this problem is that the green light & red light always stayed on at the dash after being started. Been reading and not sure what to make of it. Does it mean the generator not charging and oil not pumping?  Just changed oil this past weekend ( castrol 30 wt)? Looks like the brushes may need to be cahnged in the generator.. Again any help or advice would be appreciated.
Ron
« Reply #1 on: May 13, 2004, 10:34:58 PM »
Are the lights on at idle and go out when you rev it a little, or do they stay on all the time?  Do they come on when you turn the switch to the "ON" postition without starting the engine?
The generator light is supposed to indicate that your generator is not charging . . . of course, your battery will run down if it's not, but other than that it's no big deal to run it with the light on UNLESS it's not charging because the generator is not turning (broken belt, key out the pulley, etc.).  If the generator isn't turning, you have no airflow to cool the engine and it will only take a minute or so for it have a melt down.
The oil light is supposed to come on when the oil pressure is below a set point . . . I don't remember the exact pressure, but it's pretty low . . . something like 4 or 5 pounds per square inch maybe? . . . I don't remember for sure, but it's pretty low.
Anyway, if the lights are working correctly and they are both on, you need to pinpoint why and get the problems resolved before you run it.  Since the car sat for several years, it may just be suffering from electrical problems . . . usually just bad connections, and most often times on the ground side of the circuit.  The idiot lights share a power connection with the turn signal indicator light . . . does it work correctly?
Offline eakanator
  • Rome, Ga
« Reply #2 on: May 13, 2004, 10:44:10 PM »
Thanks, I'll check the wires, I did leave two wires loose/ not grounded around the gas tank area, When I was replacing the gas tank. The generator is truning, they do stay on idle or reved up..
BTY - my wife thinks the sport wheels look cute. Was going to leave this orginal, but if we get those wheels, that takes away from beign orginal. this is our project,  so she get 50% vote, Can you let me know how the Baja wheels look? Don't mind either set right now, this is going to be a long project and a while til it gets on the road or at least past the end of the street..
Thanks Zen
Ron
Offline eakanator
  • Rome, Ga
« Reply #3 on: May 17, 2004, 09:16:19 PM »
Found that it is the Generator light is on, but the oil light is not.. Got looking and there is a light above the generator light that is on, it is also red. The oil light at the bottom is not on. So, the lights that are on, is the green generator and the red light that is above it. The brushes do not look good, maybe I can just replace them..
Thanks for the help and info.
Ron
