Topic: Got wet !  (Read 20771 times)
Offline Bigdummy
  • Ft Worth , Texas
Got wet !
« on: March 19, 2013, 06:06:39 PM »
ok so when i started the trike on sunday gas sprayed out some where around the # 2 cyclinder and sprayed towards the front of the trike !  :o any ideas head gasket need more tourge on the bolts?
Offline Got Bug ?
  • Chattanooga, Tn
Re: Got wet !
« Reply #1 on: March 19, 2013, 08:37:15 PM »
More detail, please.
Liquid gasoline, or gas fumes, or hot exhaust gas ???
Re: Got wet !
« Reply #2 on: March 19, 2013, 09:58:39 PM »
That doesn't sound good. What type of carb setup do you have?
I can't imagine it being a head bolt too loose. Perhaps check around the fuel pump and see if it is leaking a trajectory of fuel towards the #2.
Re: Got wet !
« Reply #3 on: March 19, 2013, 11:09:52 PM »
Fred,I have seen this several times. Sometimes a carb will perk over sitting still  or overnight and fill up the  cly. that has the intake valve open and blow gas out between the cly. and the head even if the head torque is OK. I don't know how it does it but it will. Never underestimate the power of hydraulics. BUT I would still check the torque on the heads. Hard to hear a loose head with those loud ass headers I know you have. You have no head gaskets to deal deal with. I would bet on you having a loose head. 10mm head stud = 25 foot pds,  8mm head studs = 18 foot pd (no more no less) RE-JUST all valves after torque. Let me know what you find. You didn't say that the engine ran OK after it cleaned itself out . Need to know that.
« Last Edit: March 19, 2013, 11:17:49 PM by Ret.Bugtech »
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #4 on: March 20, 2013, 07:02:58 AM »
yeah david it runs fine after i dodge the gas spray.
Re: Got wet !
« Reply #5 on: March 20, 2013, 08:11:25 AM »
Explane "dodging the spray".  Hitting you in the butt while sitting on the trike?, hitting the ground ?.  spraying up in the air ?  Doesn't do it after the engine starts ?  Most of the time if the head is loose, It blows it straight down to the ground but not up in the air .  Check your oil level and make sure its not way over full with gas/oil mix.
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #6 on: March 20, 2013, 12:38:55 PM »
was shooting up towards the right front as you would sit on the bike  :-\ Also sent you a email per the website David.
Re: Got wet !
« Reply #7 on: March 20, 2013, 05:45:24 PM »
Hey Big-D. Send me you E-mail address if you care to and I will catch you up on things. Das Mahal is still standing intact. Even made it through a tornado . On your trike ,pop the valve cover off #1-2 and look/feel at the lower head nuts and see if they are loose.Report back. Say HI to the gang.
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #8 on: March 20, 2013, 06:18:22 PM »
Glad to here she still standin! fnswr@yahoo.com  love to here from ya  and anyone else! ;D
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #9 on: March 20, 2013, 06:46:56 PM »
David, i checked the oil it is way high,but my head bolts are more like 15 rather than 8 or 10 ?
Re: Got wet !
« Reply #10 on: March 20, 2013, 07:16:46 PM »
The nut is 15mm . Pay attention Big Guy !! the STUD is either a 8mm or 10mm. They just torque different amounts.   How high is the oil on the dip stick ?  Smell really gassy ? I'm I going to have to come down there and whip you in line. Dang !! I buy you books, send you to school and you still eat the pages.  ;) ;D ;D ;D
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #11 on: March 20, 2013, 07:20:01 PM »
its above the ill marks and yeah smells real gassey
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #12 on: March 20, 2013, 07:21:40 PM »
well above the fill marks
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #13 on: March 20, 2013, 07:28:34 PM »
tourqe good valves adjusted also put a shut off bettween tank and pump
Re: Got wet !
« Reply #14 on: March 20, 2013, 10:14:03 PM »
If you are using the original fuel pump,make sure its not leaking gas into the crankcase from inside(busted diapham) ).  Also make sure the neetle and seat ( in carb) is not cutting the gas off and leaking down through the intake. CHANGE OIL
