Topic: Got wet !  (Read 21586 times)
Offline Bigdummy
  • Ft Worth , Texas
Re: Got wet !
« Reply #75 on: July 04, 2013, 08:44:35 PM »
Ok gonna replace the fuel pump , how do I know which pump rod I have? what are the two lengths for the short or the long one?
Re: Got wet !
« Reply #76 on: July 04, 2013, 09:01:25 PM »
Quote from: Rob and Dave
Note: The fuel pump used with an alternator uses a 4" pushrod. The fuel pump used with a generator used a 4-1/2" pushrod. However, to make it more complicated SOME 15 degree-angle pumps can have the lever/arm way up in there and actually need a 4-1/4" pushrod. Make sure you have a pushrod of the correct length for your system.
http://www.vw-resource.com/fuel_pump.html
