Topic: generator stand gasket  (Read 1746 times)
Offline olddirt
  • East Ridge, TN
« on: April 02, 2010, 08:54:52 PM »
hey guys another stupid question
when i took the gen. stand off .There wasn't a gasket on it only the baffle. Was there suppose to be a gasket and if so do I put a gasket on each side of the baffle?
Re: generator stand gasket
« Reply #1 on: April 02, 2010, 10:23:35 PM »
PUT GASKETS ON BOTH SIDES OF BAFFEL.
I didn't do this on ASBug and it oozes oil out of that joint now.  I clean it off about once every 3 months and it goes behind the stand and gets al over everything.
2 other engines built with Gaskets, no leaky.
Put the little paper things on and forget about it...
« Reply #2 on: April 03, 2010, 12:23:17 AM »
On all the thin paper gaskets like the ones on the generator stand, I rub a little dab of high temp silicone sealer into both sides of the gasket before I install them.  It seems to help keep them dryer.  If any squeezes out when you tighten 'em down, that's too much.  You just need enough to sort'a "rubberize" the paper.
Offline olddirt
  • East Ridge, TN
« Reply #3 on: April 03, 2010, 12:47:01 PM »
thanks buglets couldn't do it without you
