Topic: Gas tank trash  (Read 2115 times)
Offline Jason
  • Ringgold Ga
Gas tank trash
« on: August 02, 2005, 08:05:58 AM »
The gas tank on my Dune Buggy has trash in it. But it is part of the body casting it's fibreglass. There is no removing it.  What would be the best way to clean it out.  :(  :(  :(  :(  :(
Gas tank trash
« Reply #1 on: August 03, 2005, 07:01:34 PM »
If the filler neck opens into the tank near the top center and you can get all of the gas out of it, you might be able to wash it out with soapy water, drain it, rinse it couple of times then run a shop-vac hose down in it and suck all the trash out.
I don't know how yours is made, but if it's like the only buggy I've ever seen with a molded in tank that might work.
Offline Jason
  • Ringgold Ga
Gas tank trash
« Reply #2 on: August 04, 2005, 07:08:15 AM »
The hose comes thru the body right above the dog house on the motor and runs behind the motor but that just mit work.Thanks :D
