Topic: Gas tank cleaning for the new year?  (Read 8405 times)
« on: December 29, 2008, 04:15:59 PM »
Stupie got a gas tank for Xmas, Well,  I got the tank a year Ago,  and I'm installing it this xmas season.    All your talk about the reliability of JP weld and gas vapors worked.   This is a previously owned gas tank that went in a fuel injected stuperbeetle.   IS it common practic to wash out the tank with water?  Will washing with water make it rust more?  Or should I just vacuum the rust the best I can?.
« Reply #1 on: December 29, 2008, 06:19:10 PM »
This is for a bus tank, but the steps are basically the same for any VW tank:  http://www.ratwell.com/technical/FuelTankRestoration.html
Here's a link to the POR-15 kit:  http://www.por15.com/prodinfo.asp?grp=FTRK&dept=12
Rolling a chain around in it to loosen up the rust and sloshing it out with acid (as described in the first part of the article above) will get the tank clean, but if you don't do something to seal it, it'll be back before you can blink.  It seems like a waste to clean and seal an old tank when for just a few dollars more you can get a new one, but if you do it right, you're done.  You'll never have to worry about it again.  If you buy a new tank, you wan't have to worry about it for at least a few months . . . maybe even a year or two, but a new tank, untreated, WILL rust.  And it will probably rust much quicker than your original.   8)
« Reply #2 on: December 29, 2008, 08:31:23 PM »
good stuff Zen,    info said ,  Yes to water hosing the the tank.  Then it went on about buying acid and things.   I'm thinking that if I fill it with waste oil that would stop the rust for a while,  Coat the tank with oil.  then fill it with gas.  I would not notice the oil smoke,     SC
« Reply #3 on: December 29, 2008, 08:36:37 PM »
SC,
Gas disolves oil and then after the 1st tank you are back to square 1.
At least you would get some "upper cylinder lubricant" in with the gas..
Hey it works for weed wackers, and I am sure that there is a weed wacker part on there some where....
« Reply #4 on: December 30, 2008, 01:50:19 AM »
If you get the loose rust out and wash it out with acid, you are almost back to a new tank (yeah, you have to buy the acid, but it's cheap).  Sloshing oil around in it will keep it rusting until you can get gas in it.  After that, you're not protected . . . but it'll take a while for the rust to come back enough to cause a problem.  It beats leaving rust in it any day of the week . . . but coating it would fix the rust once and for all.   8)
« Reply #5 on: December 30, 2008, 05:16:30 PM »
Zen,  You shared  all  this great advice,  then I ignore it and just through it in.
I hosed out the tank,  Used a leaf blower to dry it out.  Stuffed back in Stupie
« Reply #6 on: December 31, 2008, 04:13:06 PM »
SInce I had all that expensive 4 dollar gas in my wrecked Subaru.  I went out and got some clear hose,    to syphin it out.   What was wierd was that the back hatch was up when I was trying to get the suction going and then it fell down hard on my head.  Jimminy crickets that hurt. WHile typing now,  I reached up there to check the damage.  I'm leaking transmission fluid I think.  Owe.  My Sube is mad at me
So While I waited for 5 gallons to squezze thru a 1/4 inch hose.  I looked at why the ignitons fuse blows when I signal right turns.  Left turns blink no problems.  I took the light lenses off  and pulled the bulbs for fun.  Poof  fuse gone.  Stick in new fuse,  Put bulbs and lenses back in.   SOmetimes a good knock in the head is what a guy needs to figure out Vw's.
 I took the steering wheel off and pulled out the signal blinker levers switch thing.  Sweet,  The steering wheel had rubbed thru wires  so I got our my shoe box of duct tape,  After deciding that the white duct tape is best for blinker wires,  I taped it,  Yahoo.  Blinkers on bothe sides,
Back to the new gas tank,  Poured in new gas,  Found out I did not tighten all the hose well,  gas all in the spare tire well.
Stupie no start,  I'm charging the battery.  SC
« Reply #7 on: December 31, 2008, 06:09:45 PM »
:lol:  :lol:  :lol:  :lol:  Sorry.  I'm not laughing at you, I'm laughing . . . OK, let's just leave it at I'm laughing.  Hope your head isn't perminantly damaged.  I'm begining to beleive Ret.Bugtech is on to something with his "triangle" theory.  That sounds like something that would happen to me.   :wink:
Gas in the spare tire well . . . charging the battery . . . in the "triangle" . . .  :whistle:  Hope you still have eyebrows when this is over!   :lol:
WOunded
« Reply #8 on: December 31, 2008, 08:20:22 PM »
Nothing makes a post rock better than Blood.  My loving wife called me a name and made go to the 24 hr med place,  they glued my head back together  SC
« Reply #9 on: January 01, 2009, 12:38:00 PM »
Big morning for me,  Stupie started up for the New Year.   Maybe that is good Karma,  SC
« Reply #10 on: January 01, 2009, 02:30:08 PM »
Quote from: "Smelly_Cat"
Or maybe it was the blood offering you gave him?
Happy new year,
KC.
« Reply #11 on: January 01, 2009, 02:59:57 PM »
Quote from: "ASBug"
Or maybe the "magic" words you uttered when the hatch hit your head?  :oops:
I'm glad you let a Dr. glue up the gash . . . Duct tape would be painful when you went to remove it and JB Weld would dry too hard and let you continue to leak "transmission fluid."
All joking aside, glad you survived and got to hear Stupie fire up again after going to all the trouble of installing a new gas tank!  Hummmm . . . maybe I shouldn't use "fire" and "Stupie" and "gas" in the same sentence . . .
8)
Offline rokemester
Leaf Blower
« Reply #12 on: June 23, 2009, 12:11:51 AM »
Thanks for the great idea with the blower. I've been soaking my 30 PICT-1 carburetor in cleaning solvent and I need to wash it out with water and blow it out with compressed air. Although not particularly elegant, a leaf blower will do the trick. Unfortunately I don't have a compressor. Maybe someday.
Offline virgo062
  • Rossville GA
« Reply #13 on: June 23, 2009, 09:17:22 AM »
OMG that picture of Stupie on that barrel looks dangerous...SC you should not get under Stupie when he is like that. :shock:
« Reply #14 on: June 23, 2009, 09:56:53 AM »
I have known of people being killed that way.  I myself had a car fall off of some jackstands while i was under it many years ago.  scary stuff.
 :shock:
