Topic: Fuel mileage  (Read 3747 times)
Fuel mileage
« on: December 15, 2004, 12:10:16 PM »
My odomeder is "sticky" at times, for just a few miles at a time it will quit turning over, and then pick back up again just as mysteriously as if nothing is wrong.
However, I pulled in to refuel right at about 400mi, adjusted for the few miles the odometer wasn't counting. I put 12.43 gallons in there, so does that make my average miles per gallon about 32? Is that good, or should I expect more? This is pretty much all city driving between Ft. O and Ringgold and back.
Fuel mileage
« Reply #1 on: December 15, 2004, 05:40:02 PM »
Russ, Does your speed work all the time ?  If so and the odom. is the only problem,There is no fix other than replacing the whole unit.  32 to 35 sounds about right for the heavier Jetta, colder temps, driving habits and the mileage on the car.
Fuel mileage
« Reply #2 on: December 15, 2004, 06:44:09 PM »
No, the speedometer always works. Steve said he went through a couple of units before he got one that was working. Glad to know my mileage is pretty on target then. I filled up for $1.85 today...hopefully it will go down again when I fill up again next month  :lol:
Fuel mileage
« Reply #3 on: December 16, 2004, 02:49:07 AM »
If it's anything like a bug's odometer, there is a little plastic gear pressed onto a shaft inside the odometer.  There are some little grooves in the shaft that hold it tight . . . until the gear cracks.  Then the gear will slip and stop turning the odometer.  I've taken a BUNCH of them apart and fixed them.  One actually worked for .7 miles after I fixed it!  If that's what your problem is, listen to David.  Don't waste your time trying to fix it.
I don't think I've ever had this problem on a standard Beetle, but almost every Super I've had was like that.  I was looking for an early Rabbit cabrio a few years ago and noticed that almost every one of them had between 89 and 91 thousand miles.  Most of them OBVIOUSLY had more miles than that.  I'm slow . . . but after looking at about 10 of them I figured out that there might be a problem with their odometers.    :-k
Fuel mileage
« Reply #4 on: December 16, 2004, 10:02:32 AM »
Zen, I have you beat on the time that the odom. lasted after trying to fix the split gear. Over night I think.  Most std Beetles had a nice little brass gear.  I gave up on trying to fix those $%^$#* gears after I figure out that after jerking the speedo out, prying it apart @ 50 cents hr. I loss my butt.  `Taint worth it. :lol:
Fuel mileage
« Reply #5 on: December 16, 2004, 07:30:58 PM »
Several years ago when I was first getting into Volkswagens, there was a website called the VW Archives.  There was a guy on the forums there that said he had found a brass gear that was a perfect replacement for the plastic gear on a Super Beetle odometer.  He said they only cost a few pennies each.  That web site has long since vanished . . . I don't know where he got the part or what it was intended for, but it seems like I remember he said he got it at a local hobby shop . . . maybe something to do with model railroading or model planes?  Anyway, if I could find a brass replacement gear, I'd tear back into one of the many broken ones I have . . . not that I am interested in trying to make 50 cent an hour repairing them, but I've already invested many hours working on them . . . I'd like to be able to say that I did get ONE fixed!
Fuel mileage
« Reply #6 on: December 26, 2004, 10:56:50 PM »
Well I refueled tonight with dino, didn't have enough to make it out to Bonny Oaks this time. But I did better, 36 MPG and the odometer didn't stick, at least not that I noticed.
Will fuel mileage increase in warmer weather? Steve said I could get 50 in this thing.
Fuel mileage
« Reply #7 on: December 27, 2004, 08:13:59 AM »
Quote from: "Russ"
My theory there is the plastic gear in the odometer that is cracked is less flexible and sticks to the shaft better when it's cold.  I've noticed that Joy's convertible's odometer slips less in cold weather too.
Fuel mileage
« Reply #8 on: December 27, 2004, 10:22:53 AM »
Russ, Your fuel mileage should be better in the hotter months , but I don`t think you will get to the 50`s. More than likely in the high 30`s or low to mid 40`s. Remember the Jetta is heavier than Rabbits and Golfs and there is the question where your Injecter pump is set. A few degrees one way or another can dictate what kind of mileage you will get if all is well with everything else.
Fuel mileage
« Reply #9 on: January 17, 2005, 10:12:52 AM »
Went 399 miles this time on 10 gallons of gas...that's right at about 40.
At this rate I should hit 100mpg by spring.
Fuel mileage
« Reply #10 on: January 17, 2005, 11:06:36 AM »
Bully for you young man !!!!   Proper  Mantinance and care  matters  after all doesn`t it.   :wink:
