Topic: Fuel injection, '78 Bus  (Read 4647 times)
« on: September 04, 2004, 01:04:14 PM »
I have been working on Chip, Big Johnson's Westy.  It had an exhaust leak at the heads and 30 lbs. compression on cylinder #3.  After the "rebuild", the compression on #2,3 and 4 are above 90 lbs. while #1 is around 85 lbs.  The engine starts up fine and even idles (not quite right, though) and revs up good too (although in the process of "revving up", there is a long delay in getting the rpms up.  There was NO power when I took Chip on a test drive.
Fuel pressure test: 35 lbs. with pressure regulator hose disconnected and plugged...around 32 lbs. with said hose reconnected.
Vacuum lines checked and broken ones replaced...can't find a leak.  But if I soaked the intake manifold along with the throttle body in kerosene to clean it, could I have messed up the seal between manifold and throttle body?  I think I hear an air leak, but can't pinpoint it down.  I was thinking maybe there is a leak between manifold and throttle body.
Hydraulic lifters: Good resistance on most, bled the one lifter that really needed it...should the rest of them need bleeding too?  Or will they "build up" the pressure they need?
I have never* had a problem with the fuel infection (er, injection) in my buses, so this is sorta new to me...the tracking down and finding the problem.  Anyone...ahem...have the knowledge and/or time to assist me?[-o<
* "Never", in this case, means "not of this magnitude".
« Reply #1 on: September 04, 2004, 02:13:39 PM »
OK !    What do you mean rebuild ?   The whole engine, valves,piston/cly, etc ?   I question the compression #s  but if p/c`s  are brand new this could cause the low #s until the rings are seated,but not always. How did you "bleed" the lifters and did you re- adjust the valves after running awhile? Do they sound like a "hammer mill" still?  VW says 2 1/2 turns in from 0. I like just 2 turns in.  What is your total timing set on?  Should be around 32 degrees @ 1000-1500 rpm. Is the black plastic timing scale still on the engine? You can not set the timing correct without someway to find TDC. TDC is NOT marked like a type 1. You can not set the timing static. No dist. is the same. I have seen as much as 5 to 10 degrees difference in some.  Make sure your dist. vac/mech advance is working . The rotor should feel like it is spring loaded if you try to turn it by hand. Bottom line is I think your timing could be the issue. Let me know.   :?:
« Reply #2 on: September 04, 2004, 09:30:44 PM »
By "rebuild" I mean used (but not reworked) heads, pistons, cylinders that all came from the same engine.
The lifter was bled by pushing down on the check ball valve, letting oil past it, then reassembling the lifter, under oil.  But putting that retaining spring back on proved nearly impossible...a lot of resistance.  Should the oil be under that check valve?
Adjusted with 2 full turns after touching.
Didn't use a timing gun to time...did use a static light.  It does have the plastic timing scale and timing mark on pulley...just need a timing light.  By the way, I have always timed with a static light on my buses...if it's wrong, it hasn't come to light yet!
Vacuum advance is working...spring loaded allright!  Sucked on the advance nipple (ooooh!) and felt/heard the flapper and the plate moved.
OK.  Will try to time with a timing light that I either borrow or buy.
Will keep y'all updated and keep me updated on anything else y'all can think of.
« Reply #3 on: September 05, 2004, 10:40:04 AM »
Well !   I would have at least replaced the exhaust valves and inspect the seats as this is the weak link in type 4 engines.  You can`t tell most of the time when a valve head is going to "pop' off or the valve seat is going to come out of the head (common for this engine) or the valve is burning without taken the head apart and inspected very closely.   As far as static timing, if you have a dist. that desides to advance to 45 degrees for some reason(spring breaks) you would never know it,but your engine would just before the heads melt down. I know you have heard that "poping/shotgun" sound on other VW engines that was not the exhaust system. A good timing light with a advance knob would have found this problem. If you are going to work on any aircooled VW, I would highly recomend buying one of these lights. Timing set way to high is certain death for aircools. Some people set timing at 6 degrees at idle,but what is the total advance. You have to know what your dist. is trying to tell you. Press on!!
« Reply #4 on: September 07, 2004, 02:46:52 PM »
If you want to borrow one of the timing lights with the advance knob, let me know.  The computer at home's broke, so just call.  I've also got a working Holley-Weber carb setup for when you finally say to hell with the F.I.! :lol:  :oops:  :lol:
Seriously, if you're looking for a vacuum leak, don't forget to try spraying WD-40 at the hoses.  If the idle comes up, you found it!
The lifters could take several minutes to pump up at temperature.  The other way to bleed them is to put them in oil and puuuuuuush several times with a pushrod tube or rod of some type until the bubbles stop coming out.  This can take several push-and-holds while the bubbles drip out every couple of seconds.
« Reply #5 on: September 07, 2004, 03:14:20 PM »
Also, You do not have to remove the retainer spring from the lifter to bleed .  Not recommend
On the road again
« Reply #6 on: September 07, 2004, 07:41:43 PM »
Well, went to Sears and got the "good" timing light with advance dial, works great!
When Eric brought Chip over to my house, I noticed that the distributor was not lined up right...it was turned more than I had seen in my buses.  Well, I static timed it and it ran awful.  I could only get any power by putting the pedal to the floor.
What the timing light showed me is that something has/had happened to move the distributor timing gear off.  It was either put in a few cogs off, or it has jumped up in times past and the distributor just turned to make it time right.  In other words, where the mark says that the engine is timed, the mark is off and not where it should be.  When the marks were lined up, the engine ran terrible.
The timing light was useless to be able to do it right because the timing gear is off in the first place...about 20 degrees.
If I'm wrong about the timing gear not being correct, then someone will tell me...
Chip is running and has power.  When Eric came to pick up Chip, I told him about the distributor and how it wasn't right.  I did the best I could to "time it by ear".  The customer knows it and is OK with it.  If someone has a fix for this, let us know.
And as far as the bleeding the hydraulic lifters, I was only doing what the book told me to do.  Now I know that you don't have to dissasemble the darn things.
« Reply #7 on: September 07, 2004, 10:29:10 PM »
Yes you can time it right,but it would be easer to show you than to try to explain it here.
« Reply #8 on: September 08, 2004, 11:37:39 AM »
:withstupid:
You COULD pull the drive gear and re-set it.  The "How to Rebuild your Aircooled VW Engine" shows how it should line up when installed.  I've got the puller if you need it.  You have to be VERY careful that the washer around the bottom of the dizzy doesn't drop into the case when you pull it or re-install it (stick it on with some grease). ](*,)
« Reply #9 on: September 08, 2004, 12:36:05 PM »
Yeah, I knew there was a distributor drive gear puller tool that would have made the job easier...don't have one.
Chip has already gone home, but I suppose I could borrow the tool, and maybe the "How to Rebuild your Aircooled VW Engine" book and get Chip back over here and do it.  I've seen the diagram of how the gear should line up, so I knew it was possible to do.
Thanks, guys! :wink:
« Reply #10 on: September 08, 2004, 05:20:27 PM »
If you choose to move the gear,like Anthony said, DO NOT drop the washers into the case. 99.99% of time you will not get them out and they will wreck the cameshaft gear if you try to start the engine. If the gear is the wrong position, it had to be installed wrong or the dist had to have jumped almost clean out of the case for it to move. I have seen dist. come loose and move up enough to jump time, but not to cause the drive gear to skip a tooth or two. This is almost impossible without doing a BIG number on the brass gear on the crank. For the sake  of me ,I don`t why people wait until they get case bolted together and then fool around trying to get the drive gear install correctly without  the fear of losing washers.
    When you were setting the timing with your new light and using the engine mounted plastic scale and the pulley notch, your advance scale on the light should have been set on "0" Then you would use the 32 degree mark on the plastic scale on the engine. I can`t imagine that it is off 20 degrees.  Was this engine running ok before the valve problem?  I would love to look at this one.
« Reply #11 on: September 09, 2004, 12:03:29 AM »
I would love for you to look at this one also.  It is Eric Johnson's bus.  He now has it.  If y'all don't get together beforehand, maybe he can bring it to the next meeting, and I can bring my timing light.
The advance dial was set to "0".
OK, I said 20 degrees because I didn't write down at what point the notch was lined up with...it was more of an "off the top of my head" number.  I just went out to one of my buses and tried to remember about where the notch was lining up at, and it was more like a 10-12 degrees offset.  With the correct timing for his bus supposedly at 7.5 degrees BTDC, the notch was hovering around 18-20 degrees BTDC.  That was where the bus ran and sounded the best.
Question: Could I have found out how far it was off by moving the advance dial until the timing marks lined up (or would it be at TDC?) and taken the number from the advance dial to give me the difference?  Just curious.
The engine had less than 30 lbs. compression on cyl. #3 when I got it.  Either the head had gotten so hot that it warped, or the shim (seal, whatever you want to call it) between cylinder and head had disentegrated...most of it was missing when we took the head off.  Also, an exhaust stud had come loose and the exhaust wouldn't tighten up, resulting in a LOUD airplane engine sound (wasn't able to seat), and the Type 4 cooling shroud was not connected to the heater boxes (at the bottom, via 2 clamps).  Also, thermostat cable wasn't hooked up.  And, no engine compartment seal.  Most of the vacuum lines needed replacing along with the special black rubber "T" and elbow boots that these injected engines have.  It had trouble starting (cleaned the starter and the commutator and brushes inside...lots of black crud inside and out).
Sorry about the list.  The problems just kept coming and coming...
« Reply #12 on: September 09, 2004, 09:02:33 AM »
Hey !  Don`t worry about the long list. After all it is a type-2. Yes, you could have seen the timing problem as long as it was on the advance side. Since you light does not  retard , and you pulley does not have a retard notch, it would be a little hard to know what the exact degree is.
     Don`t feel rained on with the exhaust studs and copper rings deal. This arrangement was one of the most stupid things VW did. It wasn`t until the Vanagon came that VW got their heads out of their butts and put real gaskets on the exhaust ports. There is a trick to seal the older exhaust ports( ask me at the next meeting).
     Blowing the head shims could be blamed on a lot of things. Timing, heat, NO compartment seal etc:  They sometimes they just did it on their own. It was a sorry set up to begin with. I think it was the 1.8 on up that the heads came with the "step ring" cast in( no shim) . This sort of cured the problem. I said sort of. Another point is that VW managed to invent the worst cooling system for the type -4 engine.  So you really have to  stay on top of these engines to make them live very long. OK I will get off my soap box now.
« Reply #13 on: September 09, 2004, 09:33:24 AM »
OH YEAH,  You guys and gals who own vans w/ type-4 power plants can blame all your woes on a "Dude" name Dr. Karl Lotz. He was brought in from VW Brazil to head VW-AG after Dr. Heinz Nordhoff died.  This fellow is the father of the type-3, the infamous 411 and 412 and the type-4 engine that we all love and cheris.   This guy was not highly thought of at VW-AG and after a few years was shipped out. The Russian front I think.
  So there!! You now know the rest of the story. :lol:
