Topic: front torsion  (Read 4310 times)
Offline letsbuggy
  • georgia
front torsion
« on: February 05, 2002, 10:46:19 PM »
i have a problen with the front of my buggy its not got any weight so the shocks are fully extended is there any adjusting this or do i live with it
front torsion
« Reply #1 on: February 06, 2002, 08:34:40 AM »
is it abnormally high in the front?  VW's sit a little nose high naturally (and most of ours are a little higher even than the factory intended due to 30+ years causing the rear torsion arms to sag) Unless you have adjusters and they have been adjusted up I don't know what would make it sit higher than normal?
VWTrav
front torsion
« Reply #2 on: February 06, 2002, 12:52:20 PM »
Quote from: "VWHerbson"
When you remove the metal body and replace it with a shortened fiberglass body, the suspension naturally raises up a little due to the decreased weight . . . but in letsbuggy's case, that's the thickest fiberglass body I've ever seen!  I wouldn't be surprised if it's as heavy as a Beetle, so maybe it does have adjusters installed to raise it up.  If so, adjust them back down.
If you are going off road, the extra lift is desirable (it gives you more cushion when you land on the other side of the dune!) but for a strickly street driven buggy, dropping back down might improve handling.
The "easy" way to lower a torsion beam suspension is to remove some of the leaves from the torsion springs . . . lots of folks have lowered there front beam that way over the years, but it's not recommended.  It could be dangerous!
The best way would be to install adjusters on the front beam, or buy a front beam with the adjusters already installed and swap the parts from your current beam.  Dropped spindles are another option, and they are usually the best option for lowering a bug because they don't mess with the geometery of the front suspension.  But my personal opinion is since you are trying to get back to "normal" ride hight, the adjustable beam would be best.  If you do the swap yourself, you should be able to buy and install a lowered beam for well under $200.
front torsion
« Reply #3 on: February 06, 2002, 01:14:13 PM »
Quote from: "letsbuggy"
my buggy
I'm sorry, I completely blew past the Buggy Part :blush:
once again, Zen's the man, I concede to his post.
VWTrav
Offline letsbuggy
  • georgia
front torsion
« Reply #4 on: February 07, 2002, 10:09:58 PM »
thanks for the help but fore now its just going to stay high running out of time trying to get it ready fou bug a p 4  had a deth in family wifes grand mother passed lost some time there but geting back in the swing of it now its ready for paint  then see if i remember how it goes back together
front torsion
« Reply #5 on: February 08, 2002, 01:30:06 AM »
Letsbuggy,  I'm sorry to hear about your wife's grandmother.  I know all too well what it's like to loose someone close to you.  We will keep your family in our thoughts and prayers.
Is this the buggy you drove to some of the meetings or is it another one you are working on?  I remember you saying something about having one apart at our last meeting, but I can't remember if you said it was that one you drove, or if you had a new one you were working on.
Speaking of running out of time to get a buggy together for BP-4, I've got to shorten a chassis, make floor pans, intall my autostick tranny, build an engine . . . then there is the paint and bodywork and interior . . . I guess I better get busy!
Edited By Zen on Feb. 08 2002 at 01:39
Offline letsbuggy
  • georgia
front torsion
« Reply #6 on: February 12, 2002, 10:21:32 PM »
yes it is the one i drove to the meetings  its getting much nea  ded face lift  new headers and a little chrome on the engin  and is on its way to the paint shope as soon as get time  paint cost more than the car
