Topic: fouling plugs  (Read 2393 times)
Offline virgo062
  • Rossville GA
fouling plugs
« on: May 12, 2010, 06:59:13 PM »
Again...I've had feeBee back from Rick @ R&M for 10 days and already fouled another plug...What the duece? How about those non fouling plugs?
Re: fouling plugs
« Reply #1 on: May 13, 2010, 08:09:45 AM »
For crying out loud !!!!    Are you still running that dang big electric pump ?  Why did you put that thing on in the first place? It will never run right with a 30 psi pump. All that car needs is about a 3-4 psi.( like the orig. or a Facet brand electric pump) You are going to wipe that engine out by pumping to much fuel through it if you haven't done it already.
Offline virgo062
  • Rossville GA
Re: fouling plugs
« Reply #2 on: May 13, 2010, 08:54:45 AM »
No we just changed out the fuel pump...Don't you remember my last post? I said it made a humming noise...So that's not it
Re: fouling plugs
« Reply #3 on: May 13, 2010, 09:33:47 AM »
I not sure I am following you.   You change out a ELECTRIC pump to another ELECTRIC pump or changed out the orig. MECHANICAL (factory)pump to a ELECTRIC pump ? The original mech.factory pump does not make any noise at all . The FACET BRAND electrical pump makes a clicking noise(no humming) for about 3-4 sec.when you turn on the Ing. switch. The Facet electrical pump is the only electrical pump that will work without flooding the engine to death. Do you understand this ?
Offline virgo062
  • Rossville GA
Re: fouling plugs
« Reply #4 on: May 13, 2010, 09:53:51 AM »
Yes ;D We changed out a electric pump with a low pressure electric pump....here's the deal when you turn the switch (not start it) it makes a hummmmm. It already had a electric fuel pump. Oh and I got new running boards for it ;D
Offline virgo062
  • Rossville GA
Re: fouling plugs
« Reply #5 on: May 13, 2010, 10:22:16 AM »
Let me add that when we got her back from Rick she was perfect. She pulled my driveway in second gear...I have bought everything that I was told to buy..The carb, distributor and she is still running to rich. I start her the way I am supposed to gas pedal to the floor once then start. I let her warm up before I go anywhere. I am beginning to wonder if this car is possessed?
Re: fouling plugs
« Reply #6 on: May 13, 2010, 10:36:21 AM »
What is the brand of the new electric pump ?  You say low pressure on the new pump ?   Do you know the spec's on the pump ?   pressures etc.
      Be sure that your oil level is normal and not overfull with a gas/oil mix
