Topic: feebee reeks  (Read 7089 times)
feebee reeks
« Reply #15 on: June 29, 2009, 09:40:24 PM »
Quote from: "virgo062"
Rick put it on and I watched. Now she won't idle at all.
Check the wire to the idle cut off solenoid.  It should get power from the positive side of the coil.  Does it click when the power is turned on and off?  If not, there's your problem.  If it's clicking, you may need to adjust the idle speed and/or mixture screw . . . or you may need to adjust the choke.  I'd bet a little bit of money on the idle cut off not having power or not working . . . Like David said, these things "always" work decent right out of the box . . . and seldom need much more that a slight tweeking to have them working top notch.
I will ask him about the timing but I'm thinging no because he put it on and I started it up.
Was a timing gun involved?  If not, the answer is definitly NO.
So the timing needs reset?
If the points are replaced or adjusted, the timing needs to be reset.  If you loosen the distributor hold down clamp, the timing needs to be adjusted.  If you replace the distributor, the timing MUST be set . . .
If you don't use a timing light, you're just guessing.  You can set it "by ear" if you don't mind buring holes in the tops of your pistons (if you don't already know, that is a REALLY BAD thing to do).
He did look at the distributor cap and say hmmm this is a little burnt I didn't ask questions.
My first bug was wabbling like crazy going down the road, so replaced my motor mounts.  It still wabbled going down the road so I put new brakes on it.  That didn't help either so I rebuilt the engine and replaced the tail lights.  I forgot to torque a couple of the rod bolts . . . when it slung a rod and was only running on 3 cylinders, it made the wabbling worse.  So I took it to the tire store to have the tires ballanced.  They said they could ballance three of them, but that one I had been running flat on for the past month would have to be replaced.  :roll:  Whatever.  They replaced the tire and ballanced them, but my engine was still running like crap and making the car wabble going down the road.  So I bought another bug and started over.  Problem solved.   8)
My point is, don't throw money and parts at something without having a clue what's really wrong.  You might get lucky every now and then, but most of the time you will only make the original problem harder to figure out.  Wouldn't it be sad if Feebee's running problems were really due to a burnt distributor cap?
feebee reeks
« Reply #16 on: June 30, 2009, 07:55:12 AM »
Zen, You might as well give up.  The next thing we will be hearing is that "Virgo" found this blind guy at the Farmers Co-op that said he would love to take a look at FeeBee to try to take care of all these problems 8)  8)
feebee reeks
« Reply #17 on: June 30, 2009, 07:58:52 AM »
As it is signed into her hand...... Fuel Leak Helen.....
 :wink:
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #18 on: June 30, 2009, 09:04:06 AM »
No No do not give up on me. David I have stopped letting the greeter @ Walmart work on FeeBee (she quit several months ago). Here is my delima I just don't have a lot of time and David lives to far to just run to on a daily basis. We have to learn to work on FeeBee ourselves. I do have a neighbor that offered to come up and "adjust" on that carb and I told him no :D So there!! Just keep answering my questions and no one will get hurt :twisted:
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #19 on: June 30, 2009, 09:07:47 AM »
Alright now back to my problem...Rick did not change out the distributor but he did take the cap off and it was burnt. I think we are going to drag her to Justin's this week and let him take a little lookie at her. But the truth is that the carb did not work out of the box but it's FeeBee and she is possessed :twisted:
Offline Justin
  • Lafayette, GA
feebee reeks
« Reply #20 on: July 01, 2009, 08:35:43 AM »
It will get taken care of.  I am gonna go get fee bee thursday.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #21 on: July 01, 2009, 09:11:29 AM »
Electro Magnetic Cutoff Valve....FeeBee lives :D we had to take the screw out that moves in and out. It seems that the power to this little screw had never been there...Make sense?
feebee reeks
« Reply #22 on: July 01, 2009, 09:18:53 AM »
I take it that the "little screw" is the cutoff valve? The wire use to be there. :roll:
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #23 on: July 01, 2009, 09:20:05 AM »
And Zen.....I can't sell FeeBee and start over I will win this battle you may not live to see it but I will be victorious. Since I am a Virgo I over analize everything....right David?
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #24 on: July 01, 2009, 09:20:58 AM »
That is correct....
feebee reeks
« Reply #25 on: July 01, 2009, 05:12:30 PM »
Quote from: "Zen"
Hummm . . . kind'a what I thought . . . So did you brake the plunger off the end of the NEW cut-off solenoid?  It needs power for the hot (a.k.a. the positive or + ) side of the coil.  The wire should also loop from it around to the choke pull off.
feebee reeks
« Reply #26 on: July 01, 2009, 05:20:54 PM »
All I was trying to say is don't work on 10 things at once.  Do some troubleshooting and try to narrow the problem down to as small a list as possible, then work on the list one thing at a time.  If it makes the problem worse, it may be something you just did and it's not related to the original problem.  Keep working on that item until you at least get back to the original symtoms . . . then move to the next item and repeat the process until you fix the problem.  If you do something and it makes it worse then jump to something else, you may end up fixing the original problem, but have something else so messed up that you don't know it.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #27 on: July 02, 2009, 01:42:07 PM »
Yes Zen....My life is like a tornado I run 100mph all day. I need prozac I know but that's how I roll :?
feebee reeks
« Reply #28 on: July 02, 2009, 04:09:19 PM »
I used to be the same way before I got old and fat . . . and lazy.  Just slow down and take a deep breath every now and then . . . and take it one thing at a time.  Multi-tasking is WAY, WAY over-rated.   8)
feebee reeks
« Reply #29 on: July 02, 2009, 04:34:49 PM »
 I know thats the way you are  .  A tornado is a bad ass storm that makes a lot of noisy , tears up everything in sight and you never know where its headed :lol:  :lol:  :lol:
    But I still love you :?  :?
