Topic: feebee reeks  (Read 7324 times)
Offline virgo062
  • Rossville GA
feebee reeks
« on: June 26, 2009, 09:03:06 AM »
of gas...It takes about 5 miles but the gas smell is whew! I am going to take a educated guess and say it's the carb loading up and spewing gas all over the motor :D The garage smells like gas and Rick is threatening to evict her to the outdoors. Any other theories?
feebee reeks
« Reply #1 on: June 26, 2009, 09:07:08 AM »
Ya shouldn't have fed her the refried beans last night.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #2 on: June 26, 2009, 09:23:30 AM »
Hmmmm good theory but not really the one I was looking for :lol:
Re: feebee reeks
« Reply #3 on: June 26, 2009, 10:15:17 AM »
Quote from: "virgo062"
If FeeBee is leaking gas in the engine comp. you had better fix that NOW .  VWs love to catch on fire when thats the case.   If you think the carb is leaking down,loading up , check the oil for gas filling the crankcase .  If its overfull ,change your oil NOW before it burns the bearings up. You can check the tank hoses . Some Supers have had fuel leaks at the filler hoses.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #4 on: June 26, 2009, 10:23:29 AM »
OMG your freaking me out...I don't even know where the crank case is but I will check the oil though. To my knowledge all the hoses have been replaced I am expecting the carb today [-o< Maybe I can have everything checked out when I have the carb put on. You know when I am sitting still I have to continue reving the motor to keep her running I just figured gas was spewing out of the carb. I don't want to catch on fire :cry: I feel like when I light up in her I'm going to explode :oops:
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #5 on: June 26, 2009, 10:32:02 AM »
I went out and looked at the oil stick and it does not look like oil it looks like transmission fluid :shock: Oil is supposed to be dark...right? It smells like gas too of course it could be my imagination now I'm freaked and afraid to drive her...The "oil" is kinda runny too. Should I have her towed home?
feebee reeks
« Reply #6 on: June 26, 2009, 12:07:33 PM »
I would not drive it until you change the oil and then find out why .  Do you have your 30-31 yet ?
Offline Justin
  • Lafayette, GA
feebee reeks
« Reply #7 on: June 26, 2009, 12:09:13 PM »
Super beetles are supposed to smell like gasoline right?  Its gotta be the filler neck or......the dang fuel cap.  if they re not put on the correct way they can let gas spew out.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #8 on: June 26, 2009, 12:10:09 PM »
Yes the Carb just got here =D> We just had the oil changed last weekend. I am thinking I might not have had the cap on good :oops: But I am parking it till further notice just to make sure :wink:
feebee reeks
« Reply #9 on: June 26, 2009, 02:07:02 PM »
If the oil smells like gas, and is thin, your fuel pump may have taken a poop and is leaking back into the crankcase.  either that, or something is running gas down the intake into the cylinders, into the crankcase, blah blah, etc... either way, def don't drive until you figure out what's up.
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #10 on: June 26, 2009, 03:20:07 PM »
Well that makes sense...That's one part I have not replaced :lol: Thanks for all the info I'm putting FeeBee to bed until I can get someone to check her. I do have to drive her home tonight pray that nothing bad happens
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #11 on: June 29, 2009, 09:10:15 AM »
We put the brand new out of the box 30/31 on feeb and she runs worse than ever. We changed the distributor to the 009 mechanical advance and that made things worse we have ordered the genuine mexico vacuum advance distributor. God bless a Milk Cow :lol:
feebee reeks
« Reply #12 on: June 29, 2009, 01:07:30 PM »
Well ,You have the first 30-31 that doesn't work that I have ever seen and I have put on a pile of those things. Installed correctly ? :shock:
feebee reeks
« Reply #13 on: June 29, 2009, 01:16:12 PM »
Who is "WE"  Did "WE" reset the timing after the Dist. change ? If you didn't its going to be off.   Did you think that maybe the spark plugs might be fouled a bit from burning to much gas ?  When you say worse , Whats it doing ? :roll:
Offline virgo062
  • Rossville GA
feebee reeks
« Reply #14 on: June 29, 2009, 01:23:59 PM »
Your making my head spin :lol: ...Rick put it on and I watched. Now she won't idle at all. I will ask him about the timing but I'm thinging no because he put it on and I started it up. So the timing needs reset? He did look at the distributor cap and say hmmm this is a little burnt I didn't ask questions. We should have called I know. We are trying to be self sufficient
