Topic: fan scrubbing  (Read 3189 times)
Offline eakanator
  • Rome, Ga
fan scrubbing
« on: September 03, 2006, 09:20:25 PM »
another question. when I was turning the generator by hand to set the points, I could hear the fan on the other end scrubbing a little.. What's the best thing to do, pull the generator and fan and adjust? I don't hear when the motor turning, but by hand seems like there is a little fricton going on..
In John Muirs book, he also talks about puttingyour hand around the fan to check for anythign blocking air.. I didn't see much of way to get to the fan other than pulling it out..
thanks
Ron
fan scrubbing
« Reply #1 on: September 03, 2006, 11:28:34 PM »
Ron, You can loosen the band strap that holds the gen. to the stand and push or pull the gen in or out a little to clear. A lot of times this will cure the problem. Take your belt off first.
Offline eakanator
  • Rome, Ga
fan scrubbing
« Reply #2 on: September 04, 2006, 01:25:09 PM »
Thanks David
loosing the band and sliding the generator back worked perfect.. and like a dummy, seen now where I can put my hand on the back side of the fan to check the blower  and did find a wad of paper in the fan from where we painted the bug.
Ron
fan scrubbing
« Reply #3 on: September 05, 2006, 08:26:19 AM »
Ron, I'm suprised that you didn't hear the "junk' in the fan. Sounds like a "roaring turbo" when you rev the engine.  Depending on the size of the trash in the fan, this can cause overheating. I have seen engines burn down from this problem. I pulled a #10 Rat out of a fan onetime. YUK!!
     Happy that the "rubbing" thing went away.
  Come See Us !!
fan scrubbing
« Reply #4 on: November 10, 2006, 02:30:07 PM »
Ived been hearing a vroomy noise with stupie lately.  I pulled the pully off and spun the generator and did not hear anything. then I re read this post/  I'll. reach back there and see if I got a rat in there.   I figure rodents who escape from cages think the VW fan is exercise wheel and are in there working out when we crank the engine .  sc
fan scrubbing
« Reply #5 on: November 10, 2006, 03:41:38 PM »
Be kind to the rodent if he is there. Keep him well groomed and fed. You will never know how handy he might be if you break a fan belt at 2;00 am in the middle of nowhere. Just think,a rodent in good physical condition running wide open might deliver 40 or so Amps.  Of course this is if you are using a # 10 wireless rodent. I don't think you would get much out of a "Triangle" raised Chinchilla. :lol:
fan scrubbing
« Reply #6 on: November 10, 2006, 05:12:45 PM »
Yep I thought my engine had been swapped for a Porshe turbo then I found a bunch of leaves in the fan. oh well.
fan scrubbing
« Reply #7 on: November 11, 2006, 09:52:43 AM »
I gathered my courage and reached behind the fan.  I thought I heard a squeak, but it may have just been a rusty hinge.  Yep Leaves,  SPun dry.  I like the design of the engine lid.  IF its covered with leaves and you don't want to litter the road, just raise the lid  , all the debris falls into the intake fan and is mulched up... Sweet.  SC
fan scrubbing
« Reply #8 on: November 17, 2006, 06:08:40 PM »
Dang it Godfather!  You can question our mechanicing ablility, and we are cool with that . . . you can laugh at our painting skills, and we are cool with that . . . but when you start talking bad 'bout our rodents, I'm begining to think you're just picking on us folks down here in the "triangle!"
 :lol:  8)
