Topic: Exhaust...cough...cough...  (Read 8078 times)
Re: Exhaust...cough...cough...
« Reply #15 on: August 16, 2011, 11:25:14 AM »
I always found the best way to install a type 4 heater box was with the engine out of the bus, and on a stand, and flipped over so that you could let the weight work for you, not against.   ;)
A stand is good thing, but,but you keep your feet out from under the "bouncing" stand as you beat and pry the boxes off. Scary
« Reply #16 on: August 16, 2011, 11:37:59 AM »
Very true... those t4 engines are a tad heavier than a bug engine.
« Reply #17 on: August 16, 2011, 12:03:28 PM »
It becomes very clear what the value of a "tad" is when that thing lands on your toe. Yikes !!!!!!!. It will teach you a new language that even the "Rosetta Stone" doesn't know :o
« Last Edit: August 16, 2011, 12:05:37 PM by Ret.Bugtech »
« Reply #18 on: August 16, 2011, 12:08:21 PM »
Looks like I will be removing my heater boxes soon to tackle an exhaust leak. I got new gaskets.
« Reply #19 on: August 17, 2011, 07:51:04 AM »
[/quote  You lucked out on your gaskets. I think you have a Vanagon engine that uses real gaskets and not the dumb copper "O" rings.
« Reply #20 on: August 17, 2011, 08:38:00 AM »
It's a Vanagon engine, but regular bus heads.
« Reply #21 on: August 17, 2011, 11:54:04 AM »
Did Richard change the heads ?
« Reply #22 on: August 17, 2011, 03:24:33 PM »
Well I didn't change them, so he must have!
