Topic: Electrical Help!!!  (Read 2888 times)
Offline Ruttco
Electrical Help!!!
« on: April 07, 2009, 09:42:40 AM »
Ok, my son's 77 camper is looking better every day, but I can't get a few electrical things working and would love some help.
Blinkers - I have gotten the tail lights, brake lights and backup lights to work most of the time, but I am having no luck at all with the blinkers. The flasher switch was apart so I put it back together, suggested on another forum, and wire tied it. The arrows on the dash do nothing also. Is all the blinker function in this switch?
Wipers - They worked fine up untill about 2 weeks ago now they do nothing.
If there is anyone out there that has been there done that and would have any suggestions or be willing to take a look at it please let me know. The bus runs so I could bring it to you. I could buy the beer or something.
Electrical Help!!!
« Reply #1 on: April 07, 2009, 11:29:41 AM »
I take it you are talking about emer. flasher switch in the dash ?    If the plastic piece comes off the metal case, Its toast. That thing is loaded down with little spring loaded contacts . The odds of that switch ever working again is nil so start there.
Offline Ruttco
Electrical
« Reply #2 on: April 07, 2009, 01:00:58 PM »
Ok, I will start with that. Do they have those at Mainly Foreign
Electrical Help!!!
« Reply #3 on: April 07, 2009, 03:13:09 PM »
They should still keep them, if not al johnson vw maybe, or mid america motorworks.
Electrical Help!!!
« Reply #4 on: April 07, 2009, 04:42:31 PM »
I got a good used one from Alvin in Dalton Ga.  $9 and it even had a platic ZIP already on it!
It was for my 1972 Beetle - Man that was a PAIN to put in by myself.  If a bus one is that hard, get an assistant to hold it into place while you screw on the bezel around the shaft.
Electrical Help!!!
« Reply #5 on: April 07, 2009, 09:09:02 PM »
All this talk about putting light switches back together makes me a bit nervous....
I have seen more than one electrical fire start up in a beetle / ghia due to a light switch popping apart, the hot lead grounding, etc, etc.....
At least with a bus, the fuel tank isn't located right there.... :shock:
Offline Ruttco
Electrical
« Reply #6 on: April 08, 2009, 07:38:27 AM »
Thanks for the help. I guess I will call around and see who has what.
Oh yea, I keep a fire extinguisher between the front seats just in case.
Electrical Help!!!
« Reply #7 on: April 08, 2009, 07:52:01 AM »
Smart man.... no bus is complete without a fire extinguisher,,,,
Seriously.
Electrical Help!!!
« Reply #8 on: April 08, 2009, 08:35:09 AM »
Seriously.
Kermy has one of those really large 3' high 8" diam ones under the Zbed.
After hearing about too many fires, I decided to get the largest one I could find...
Still looking for tires for the Westy.
Electrical Help!!!
« Reply #9 on: April 08, 2009, 03:48:30 PM »
Under the bed= too far away, keep it closer... :D
Electrical Help!!!
« Reply #10 on: April 08, 2009, 05:12:26 PM »
Having a big extigushier is good, but like Rick said, if it's under the bed, it's too far away.  If it catches fire, the bus will be burnt to a crisp by the time you get the extingusher out.  You need one you can reach from the driver's seat . . . and maybe a second one you can get to by opening the rear hatch.  Getting the fire put out quickly is the only way to save it.
