Topic: Electric Choke  (Read 2026 times)
69slambug
Electric Choke
« on: January 26, 2005, 10:06:20 AM »
I have a Solex 30 pict 2 that I recently rebuilt and I have everything adjusted except the choke.  I need it to stay on just a little bit longer, how do I make it do this?
Electric Choke
« Reply #1 on: January 26, 2005, 10:48:24 AM »
Hey, Not a problem. If your choke element has a notch present, it should be lined up with the raised indicator cast in the metal housing holding the choke element. This the normal setting. If you think you need a little more time with your choke on, you can loosen the 3 screws and turn it a tad counter clockwise to add choke time. This is a trial and erro thing. Are you using a stock air cleaner with a pre-heat pipe or some "micky mouse" cleaner ?  With this kind of weather, Pre-heat is good. Most VW stock engines love warm air in the winter time just like me. :lol:
69slambug
Electric Choke
« Reply #2 on: January 26, 2005, 10:59:45 AM »
Yew I do have the stock oil bath, so I am feeding it warm air all of the time.
Electric Choke
« Reply #3 on: January 26, 2005, 11:24:36 AM »
Good !! Its nice to know that some people are not trying to second guess Wolfsburg all the time. They figured this all out a very long time ago.
      I didn`t mention this before,  but do those adjustments when the engine is cold and make sure the choke is not binding anywhere. Press on !!
