Topic: does a washer go behind the alt pulley  (Read 4170 times)
« on: June 02, 2009, 06:38:52 AM »
the back of my alt pulley is rubbing a screw that holds the alt together.  IS there suppposed to be a washer between the pulley and the Alt?  or maybe the pully is worn our?   SC
« Reply #1 on: June 02, 2009, 07:33:42 AM »
There is a small spacer that goes on the shaft.
« Reply #2 on: June 09, 2009, 06:47:37 PM »
Thanks  Bugtech,  I got big washer for 29 cents at the HW store,  It did not fit,  I spend 40 minutes with a poinnty  grinder attachment to get the inner washer hole the right size,
Now I must ask,   does a lock washer go on the outside to hold it all together?.  I seem to keep getting looserer.  SC
« Reply #3 on: June 10, 2009, 08:41:18 AM »
No lock washer, but you should have 8-10 big, thin washers stacked, otherwise stuff ain't gonna hold together right....
« Reply #4 on: June 10, 2009, 04:55:00 PM »
Wait, I thought you fixed everything on the car with old rubber gloves....
« Reply #5 on: June 10, 2009, 05:51:58 PM »
There aren't that many rubber gloves on the face of the earth... he has to use other found objects.
I guess we should give him a little credit for really working the "Re-use" portion of the recycling triangle....
 :wink:
« Reply #6 on: June 10, 2009, 09:01:36 PM »
I have 6 washers,  one of them got destroyed when the pully went loose.
 I'z gots togo shoppon
« Reply #7 on: June 11, 2009, 12:01:04 AM »
We are not talking about the same spacer. :roll:
« Reply #8 on: June 11, 2009, 08:02:18 AM »
ONE small spacer 3-4mm tall, fits over the shaft of the generator, small diameter, that spaces the pulley outward.... then, 8-10 large spacer washers for the pulley itself....
« Reply #9 on: June 11, 2009, 08:55:25 AM »
Glad you explained that . I felt a headache coming on about then and the Grog was getting  low in my stein . :lol:  :lol:
« Reply #10 on: June 11, 2009, 10:23:07 AM »
Got your back, Godfather.... :wink:
Smelly Cat is too much for just one mere mortal man to handle.....
« Reply #11 on: June 11, 2009, 01:23:51 PM »
Or even a Ex- mortal man.   Somebody has to take over after I commit murder. :shock:  :shock:
« Reply #12 on: June 11, 2009, 02:24:30 PM »
:shock:
Good Lord.....
« Reply #13 on: June 11, 2009, 08:37:41 PM »
I stuck a screw driver in the pully and torgued the nut till it hurt .  I drove to work and it did not loosen .   So victioy is Mine say us the SC
thx fer the help.  tech"S
« Reply #14 on: June 12, 2009, 07:59:47 AM »
I am assuming you took the screwdriver out when you got done, right.....
 :roll:
