Topic: Do you know...  (Read 1769 times)
Do you know...
« on: February 22, 2010, 09:15:05 PM »
....which of the two blades without a wire connected to them, do you connect the fused wire (black/red) from the regulator to?  I believe this is the relay for the rear window defroster.
Do you know...
« Reply #1 on: February 23, 2010, 12:09:08 PM »
JR, The relay you are showing is not for a rear window defrost . Looks more like a old H/L dimmer relay. I had to go find my old factory parts book to find the correct relay parts #.
   The part # is 111-963-141B.  It should be a cube shape( about 1 inch square) and has a screw mount tab and only two connectors. Hope this helped
Do you know...
« Reply #2 on: February 23, 2010, 12:13:55 PM »
By the way the relay mounts on the floor pan rear cross member left side
Do you know...
« Reply #3 on: February 23, 2010, 08:33:10 PM »
This one is mounted exactly where you noted.  My problem is I have one wire, which is fused, that connects from the regulator and I believe to this relay.  I have looked at wiring diagrams but still not sure where to connect it.  I do believe that this wire goes to the relay but can't be 100% sure.  If it does not connect to this relay, then I have no clue where to connect it to.  Maybe if I state where it comes from on the regulator, that would help.  I will have to check tomorrow evening.  Thanks!
Re: Do you know...
« Reply #4 on: February 24, 2010, 09:28:55 AM »
JR , Send me the part # on that relay
