Topic: distrbuter cap button  (Read 1640 times)
« on: May 26, 2008, 10:16:24 AM »
Does the little spring button in the middle of the cap ever wear out?.  Stupie was sputtin and lurching and it looked like the button that touches the rotor was barely touchin   sc
« Reply #1 on: May 26, 2008, 11:12:31 AM »
Sometimes they will wear and they can get stuck up in the cap where they will not touch the rotor.  I have seen them bad enough to burn the top of the rotor out and causes the restistor in the rotor to fry. All this doesn't happen very often but can.  This may not be causing the problem you are having unless you can see the damage( Plugs, plug wire connectors, etc.etc.)  I think the rotor supposed to have 10 to 12 ohms res. You need to tune Stupie up all at one time and not patch at it.
