Topic: Cv joint bolts  (Read 6145 times)
Offline lndixon
Cv joint bolts
« on: May 26, 2013, 02:53:01 PM »
Any helpful hints on how to break these bolts loose with out stripping the head out? I've been letting the soak in PB blaster.
Re: Cv joint bolts
« Reply #1 on: May 26, 2013, 03:28:58 PM »
First thing you do is to CLEAN the hole out COMPLETLY. I mean COMPLETLY. If you are using the serrated allen type socket on a 3/8 ratcet, Tap the head of the bolt with hammer(like driving a nail) then tap the socket in with a hammer and hold it straight and start pulling. If that doesn't work then its time for a really good pair of Vice-Grips.  ;D  I have Air so I use my 3/8 impact wrench. They can be little "boogers" sometimes even with a air wrench. Good luck and let us know. You are not the first one to have this problem .
« Last Edit: May 26, 2013, 03:31:09 PM by Ret.Bugtech »
Offline lndixon
Re: Cv joint bolts
« Reply #2 on: May 28, 2013, 10:06:01 PM »
Well Ret.bugtech, just as you said cleaned then right up and they come right out. I know It's my vw and all but 4 of the bolts are not going back in. Should I replace them with vw cv joint bolts or would standard metric socket heads be ok?
Re: Cv joint bolts
« Reply #3 on: May 28, 2013, 11:50:18 PM »
I think I would stick to the originals .
Re: Cv joint bolts
« Reply #4 on: May 28, 2013, 11:57:39 PM »
For future reference on this incase any one else ever has this same problem, a dental pick set is your friend here. The more "crap" you get out of the socket, the better the odds of not stripping out the head.
Just my $0.02 here.
Re: Cv joint bolts
« Reply #5 on: May 29, 2013, 01:50:37 AM »
I don't think Bonnie came with a Cirriculum Vitae. If she did, it wasn't bolted on with dirty bolts...  ??? ::) ::)
Re: Cv joint bolts
« Reply #6 on: May 29, 2013, 08:48:39 AM »
It would be a heck of a defucaldy if she were.
Re: Cv joint bolts
« Reply #7 on: May 29, 2013, 10:27:48 AM »
Show off.
Re: Cv joint bolts
« Reply #8 on: May 29, 2013, 02:02:46 PM »
Show off.
Matter of fact I have one of those. Its sitting on my Volvo's cruise control lever. ;D ;D
Re: Cv joint bolts
« Reply #9 on: May 29, 2013, 03:25:43 PM »
Show off.
Re: Cv joint bolts
« Reply #10 on: May 30, 2013, 01:10:31 PM »
Show off.
I have to get my diacritics correct. Its not on the cruise stalk, Its in the glove box. ;D
Re: Cv joint bolts
« Reply #11 on: May 30, 2013, 01:13:59 PM »
Show off.
Now don't go all "dying a critic" on us ;D ;D
Re: Cv joint bolts
« Reply #12 on: May 30, 2013, 01:30:13 PM »
Show off.
Why would I do that ? You are living proof that my job is not done yet. 8) 8)
