Topic: Clutch return spring pressure question  (Read 8581 times)
Offline Got Bug ?
  • Chattanooga, Tn
Re: Clutch return spring pressure question
« Reply #15 on: September 12, 2013, 10:26:18 PM »
I'm going to have to replace the trans someday, first gear synchros are shot. The trans is okay otherwise but I see it in the future. I'm glad to hear the m/cycle jack works to pull the motor. I'll remember that.
Who am I kidding...in a few days I'll have forgotten I even typed this!!!
« Reply #16 on: September 12, 2013, 11:39:11 PM »
Change the gear oil in the transmission.  Replace one quart of it with Lucas.  I thought the transmission in my S-10 was about shot years ago . . . I was amazed at what replacing the thick, dirty goo inside of it with clean oil and Lucas did for it.  It shifts better today than it did 75,000 miles ago!
Oh, yeah, a tip for you if you decide to change the oil in it . . . Remove the Fill Plug FIRST . . . then remove the drain plug.   ;)  There's nothing like the feeling you get when drain the oil and then figure out the fill plug is stuck . . . especially when it's your daily driver.   ;D
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #17 on: October 23, 2013, 09:49:18 PM »
Okay...I'm slow to update. Thanks for the drain and fill plug tips. Thanks for the Lucas additive tip. I did both as you suggested. My trans is still about the same syncho-wise, but I feel much better having fresh lube in the trans.
I found a split axle boot and replaced it. Also the ground strap from Trans to frame. I have been complaining about weak lights for a year of so and had my suspicions about that strap. I should have done the strap replacement a long time back. It wasn't hard and my lights are much improved. Still 6 volt lights, but a lot better than before!
Offline Aircooled Werk
  • Ringgold, Ga
    • Aircooled Werk
« Reply #18 on: October 27, 2013, 10:42:18 PM »
If you have shift problems, don't let them get too bad. I routinely have to replace more parts because of parts warn beyond limits. Cheaper to rebuild early rather than when sliders or clutch gears are too worn.
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #19 on: October 29, 2013, 06:10:40 PM »
Good advice. Thanks. I'm hoping to make it through the winter at least and had thought about installing a rebuilt trans somewhere down the road. No pun intended. It's been consistent for about 10k miles now.
« Reply #20 on: October 29, 2013, 09:55:53 PM »
Get Tony (aka takeflight) to look at it. He rebuilds them and knows a lot about them. He would probably be able to save you money if you think about fixing it before more breaks. From what I've heard, he is very affordable compared to most places.
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #21 on: October 31, 2013, 10:36:14 PM »
Well...I'm driving it about every day now, so I don't want to pull it down. I'm a very slowwwwww mechanic. Maybe when warm weather comes back.
Is it better/cheaper to rebuild the original or just get a rebuilt from Wolfsburg or similar?
« Reply #22 on: October 31, 2013, 11:54:50 PM »
It will be significantly cheaper to have it rebuilt than having to freight one to you and then swap it before freighting the old one back. You could get one from up in Smyrna TN from rusty bottom garage and swap it in. Tony could rebuild yours right here in town. From what I understand, he is a heck of a lot cheaper and no freight. If you have a problem, you'll know where he lives and everything. I plan on getting one built by him one day. Just not sure when I'll need it!
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #23 on: November 01, 2013, 10:02:02 PM »
Thanks, that's the kind of info I love to hear...competent, respected, local...and I can save money!!
I'm going to see how much longer I can make this last, but it looks like Tony's got a customer headed his way sooner or later!!
