Topic: Carpet Conundrum  (Read 2861 times)
Offline Bugz
  • Burlington, NC
Carpet Conundrum
« on: March 08, 2004, 12:54:21 PM »
I'll be in the market soon for some carpet for my 72 beetle. I know they make the one piece for the entire floor as well as the sectional piece set. Is there any advantage or disadvantage of one over another? I'll also be installing floor pans this summer, should I wait on the carpet till after that or is carpet easily removed and reinstalled?
Carpet Conundrum
« Reply #1 on: March 09, 2004, 08:11:12 PM »
I haven't had much experience with bug carpet but I think I've heard the one piece is NOT the way to go. There is just too many bumps and holes and bends and etc. I wasn't even aware there was a 1 piece carpet set available. Let's see if someone else responds to this before you buy anything.
        :cool:
Edited By vwherb on 1078881106
Carpet Conundrum
« Reply #2 on: March 09, 2004, 08:44:35 PM »
Haven't installed any carpet, but I've ripped up a few.  They were all held in place with adhesive, and in some places the adhesive was gobbed up and nasty to remove.
I don't know if the sectional piece set is to be adhered to the floorpans, but I'm pretty sure that the one piece should be. ???
So, just in case you have to adhere the carpet, think about having to take up the carpet for the floorpan replacement when you do it and decide if you want to do that extra work. :cool:
Carpet Conundrum
« Reply #3 on: March 09, 2004, 10:59:40 PM »
I've never installed a "one piece" carpet, but I have seen them advertised.  A place called Automotive Custom Carpet just a block from my house used to make these molded one piece carpets for just about any car made since the 60's.  They do have a couple of advantages . . . they are one piece, and molded to fit the floor.  They would probably be a breeze to install, and wouldn't have all of edges that might come loose in the stock style carpets.  Even so, I'd prefer the stock multi-piece style.  They are pretty easy to install, and if you ever need to do someting that requires working under the carpet (adjusting your shifter, replacing the shift rod bushing, replacing the brake line from the master cylinder to the back of the car, etc.) you don't have to remove the whole interior.  With a one piece carpet, you would have to remove both seats, the panels under the rear seat, and the entire carpet to do any one of those jobs.  With the stock style, you just peel back one or two pieces, do your work, and stick 'em back down with spray adhesive.  Just be aware that there are lots of grades of the stock style carpets . . . You will be much happier with the finished look if you spend a little extra and get one with bound edges even if it's a cheap grade of carpet.
By the way, in addition to the glue, the originals had 3 or 4 upholstery tacks in the kick pannel pieces.  If you just glue them in place, they will be falling off in a year or two.
