Topic: Carb swap out  (Read 2553 times)
Carb swap out
« on: April 21, 2008, 07:56:45 PM »
So I managed to pick me up a brand new 30/31 at BAP.  I figured I needed to change mine since every time I turn off the engine it drips from the accelerator cable linkage and the fact that it stalls every time you come to a stop if you don't keep your foot on the gas.  Of course you know I'm running a 28 with the original govenor.  Here is the questions.
Can I continue to use my govenor? If not, Can I bolt the carb directly to the manifold or do I need to use a spacer?
Carb swap out
« Reply #1 on: April 21, 2008, 11:50:02 PM »
Brian,  I suppose you have tried to deal with the 28, rebuild etc?   I think you are supposed to have a 30mm carb to begin with. 67 right ?  Does the gov. work ?   I think you can use the gov. but you might have to change some studs .  Been to long can't remember. If you don't use the gov.  you will have to use a spacer I belive to keep the carb accel. pump housing  from hitting the gen. If the gov. does not work, you could gut the thing and use the housing for a spacer.
Offline Roadkill
  • Ooltewah Tn.
Carb swap out
« Reply #2 on: April 22, 2008, 12:53:38 AM »
hey Brian,  if your 67 is any where like my 69 ( i have a 30 / 31 carb ) on mine. When i put my new one on i tried it without the spacer because it did come with it. I found it did hit the generator. So i took the spacer from the old carb on the engine and it sat fine as you saw when you were at my house. .........Rob
Carb swap out
« Reply #3 on: April 22, 2008, 09:36:45 AM »
I did rebuild the 28 carb but I think I cleaned it up so well that I opened up some air gaps.  The bus is a 67.  Govenor works great.  I had previously bought a spacer just in case the govenor closed up on me.  I just wasn't sure if the govenor was setup specifically for the 28 carb since it has 28 stamped on the front of the govenor.
Carb swap out
« Reply #4 on: April 22, 2008, 09:58:14 AM »
With the gov. working off the intake vacumn port , I'm not really sure if it would make a lot of difference. You can re-calibrate the gov. if you want to mess with it. I'm surprise it still works at all. :shock:
