Topic: cannot keep my 73 super running  (Read 2320 times)
Offline roymcneese
  • chattanooga
« on: December 22, 2009, 07:09:56 PM »
i was wondering if anyone can help. go a 73sb. not had it long. but now it would not turn over at all. i had to push start it. will stay running. but just turns over no running. the oil light comes on when i let off the gas. crazy wiring.
2nd issue is doesnt seem like it has any power in 3rd or 4th grear. was going to work this morn and hme this evening and freeway speed was only around 45-50 at the most. any help would be greatly appreciated
« Reply #1 on: December 23, 2009, 12:15:58 AM »
I'm not sure understand the symtoms . . . You can turn the engine over with the switch, but it won't start?  But if you push start it, it will run?  If both of those statments are true, I'd put 99 to 1 odds on a bad ignition switch.  The originals would last 25-35 years, but these cheap replacements that are out there now will last a year if you're lucky.  The good news is that after you've changed it once or twice, it gets pretty easy to do.  When I was driving a 74 Super and my wife was driving a 75 Super convertible as daily drivers, I could change the ignition switch blindfolded, in the dark with one hand tied behind my back.   8) OK, that may be a little bit of an exageration . . . it takes two hands . . . :D
If I understood you right, the oil light comes on at idle?  That could be something as simple as the wrong grade of oil (but that usually isn't a big problem in cold weather) or the idle set too slow or something as major as the engine bearings worn out . . . or a bad sending unit, sticking pressure relief valves, etc.
On the power issue, it sounds like you my be running on 3 cylinders instead of 4.  If the power dropped suddenly, look for something simple first, like maybe a plug wire came loose or the insulation rubbed through and grounded it out.  It could be just in need of a good tune up.  Have you adjusted the valves, replaced the points, set the timing, replaced the plugs, etc. since you've owned it?
Offline roymcneese
  • chattanooga
« Reply #2 on: December 29, 2009, 09:12:33 PM »
thanks for the help. i put the ignition switch on tday. piece of cake.1st time only took me about 25min. was proud of myself. but sad to say didnt fix the problem. the switch just turns over with no noise at all. not even trying to start. battery is hot. maybe if you dont mind i can call you. or maybe just tell me what else to look for. thanks again for you help
« Reply #3 on: December 30, 2009, 08:35:48 AM »
Have you checked the wiring at the starter to make sure that nothing fell off ?
   I take it that the warning lights came on in the speedo when you turned the switch on ?  You might try this although it may be little hard to do on the ground and may take 2 people.  Take a volt meter and put the positive  (+) lead to the small wire ( should be red) on the starter and ground the other lead.  Set your meter to 12-24 volts DC and have someone go to start on your  switch and hold it there. You should read some where around 12 volts. If no voltage , trace the wiring from the starter back to the switch. If you do have voltage (I love this) wack the starter case with a hammer and try to start. If nothing happens you MAY have a bum starter motor.   Just remember that you are there and I'm here and I'm going on the info you are giving me.
