Topic: cannot change gears with engine running - will change not started  (Read 2551 times)
Offline eakanator
  • Rome, Ga
Finally got the bug started and running. Found though when I depress the clutch, cannot change gears. If I hold in on the clutch, and hold it first it will try to roll forward, but never engage.. When the car is not started, you can go through the gears. Any ideas would be appreciated.
Ron
« Reply #1 on: May 14, 2004, 01:57:31 AM »
Just going off what you say, it sounds to me like the clutch is not engaging, ie. throwout bearing not "throwing", clutch cable too loose or broken, etc.  Or the clutch is worn.  Maybe Zen can answer this. ???
I had the same problem (of sorts) with my Westy.  Only it wouldn't go into any gear until the engine warmed up.  Still don't know what was causing that, except I think that was around the time that the shift rod bushing right in front of the transmission fell apart on Hwy. 64 by the Ocoee river.   :;):
Offline eakanator
  • Rome, Ga
« Reply #2 on: May 14, 2004, 08:34:27 AM »
That sounds logical, I know the previous owner said he put a new clutch, etc in, but your talking 15 years ago..Is there a self check or step by step to find out( anything to ping it to break loose if stuck or bleed something) . I have the back seat out and the plate over the knuckle off. you can depress the clutch pedal ok  and it seems to come back ok.
Ron
« Reply #3 on: May 15, 2004, 10:04:15 AM »
Do you have a lot of freeplay in the pedal?  If you have too much, the clutch won't relase completely.  It will cause the symptoms you described.  The pedal should move without much resistance for only about an inch, then you should get a definite increase in resistance.  There is a wing nut on the end of the clutch cable (where it passs through the throwout lever on the driver's side of the transmission bellhousing). . . tighten it to decrease the freeplay.
Offline eakanator
  • Rome, Ga
« Reply #4 on: May 17, 2004, 09:06:08 PM »
Thanks, I'll look at that.
Ron
Offline eakanator
  • Rome, Ga
« Reply #5 on: June 13, 2004, 08:05:27 PM »
As a update, I guess, got lucky, what ever the problem, it fixed itself. Maybe just stuck after 15 years, but it started shifting and has been very smooth..
Ron
