Topic: broken gas cable  (Read 2138 times)
BugNOut
broken gas cable
« on: December 07, 2005, 04:59:06 PM »
Hey, guys, I feel like I'm just using you for info. Could be 'cause that's what I've been doing, huh? I broke the z-bar off the end of the cable where it attaches to the gas pedal. I've got a replacement but wanted to run it by you guys in case there are any tricks or "don't do this" involved that I need to know about. Thanks!
Offline Jason
  • Ringgold Ga
broken gas cable
« Reply #1 on: December 07, 2005, 07:54:02 PM »
It's easy as pie just pull the old one out and feed the new one thru from in side the car back to the motor.
BugNOut
broken gas cable
« Reply #2 on: December 08, 2005, 11:22:33 AM »
10-4. Thanks!
broken gas cable
« Reply #3 on: December 15, 2005, 08:40:33 AM »
Also, rub the cable with grease before you install it. Do this as you feed it in. Otherwise you get a greasy cable flapping 'round your interior.
