Topic: Breaking up is hard to do... Seperating a Ghia from it's pan  (Read 1983 times)
« on: September 11, 2009, 09:49:52 AM »
Hello,
I need some pointers about lifting points, techniques and heads ups for seperating a ghia body from it's chassis.
I am thinking about:
1- getting some help and lifting it up by my hand, or
2- roping off to some trees and lifting it off that way with come alongs (need lift point ideas...).
I have a friend that has a lift, but no way to move it home afterwards...
Ahh the journey begins.
I just bought a new set of HEAVY guage thing pans from the Thing Shop, and I am still mulling over the '68 Ghia that has already got new pans installed.
« Reply #1 on: September 11, 2009, 03:54:36 PM »
You can replace the pans without removing the body unless you just want to for the heck of it.  Its not hard to do just a pain in the butt. Take all the wiring loose at the engine, heater hoses from the engine to the body, Master cly wiring and brake fluid hoses, fuel hose at the gas tank (You can take the tank out to lighten the load)   steering shaft at the box, all the bolts around the pan underneath the car. 17mm bolts(one per side) under the rear fenders on the shock mounts,  13mm bolts across the pan inside the car in the back by the shift coupler .  Take the seats out so you won't have to lift it so high .  I,m sure I have missed something but if any wire that goes from the chassis to the body , take it off at the pan. All wires stay with the body.
      Then find 4 strong men or 6 weak'ns , shake the snot out of the body to break it loose. If it doesn't come loose, go find the bolt you forgot take out.
      I guess you do know that the '68 has a swing axle and your '73 has IRS if it makes any difference to you.
     See, its not hard to do .Its just a pain in the arse  . Have fun !!
« Reply #2 on: September 11, 2009, 04:25:26 PM »
Agreed... just a bit of a pain in the butt.  that thing has been stuck together for a number of years, so it is gonna stick.  One bit of advice.  if it's rusty, particularly in the rockers/ pillars, do not open a door while the body is off of the pan.... unless you want it not to shut right anymore.... :oops:
 :wink:
