Topic: Brake light problems  (Read 2654 times)
« on: June 03, 2006, 07:05:18 PM »
I had alot of problems with my 67's brake lights when I got it. Turned out it had some bad wiring where the PO had it wired for trailer lights.
Anyways after driving in the slosh pit of BP8 my tail lights have never worked right. First they didn't work at all and now they work, but not when my headlights are on. The taillights are really bright when the headlights are on so maybe the brake lights are staying on?
Ive cleaned the contacts and check the wires and can't find it. Any ideas?
« Reply #1 on: June 04, 2006, 10:32:08 PM »
My somewhat limited experiance with Volkswagen light problems has convinced me that about half of the time you have a problem with a light, it's due to a bad ground.  The other half of the time it's due to a bad connection at the bulb itself.  The other have of the time something else.  The rest of the time it's a combination of two or more of the above.  Start with the grounds . . . make sure all of your ground wires have a good electrical connection.  Just because it's a tight mechanical connection doesn't always mean it's a good electrical connection!
« Reply #2 on: June 04, 2006, 11:34:26 PM »
As Zen said, check the grounds first, then probably second, and maybe third.  When it comes to brake lights, sometimes the switches on the master cylinder will fail as well.  Step one, with the key on, see if you're getting power to the switches (check using a test light first at the terminal of the fuse panel headed to the brake lights, usually a black/red wire that disappears into a hole in the trunk area above the left fron wheel arch,and then on the connector/terminal of the switch itself with a test light hooked up to a good ground or, if you're really high-tech, with a multimeter.  If you're not, head back up to the fuse panel and check the fuse/wiring to the brake lamp switch.. If you are getting power, and you've still got no brake lights, the culprit is often times the switch (although, we can't rule out those pesky grounds or bulb sockets).  Another little trick to cure acting up lighting on any old bug? go through the fuses on the fuse panel one at a time, twisting each one and then check your lights again.  I can't tell you how many lighting and other electrical woes we performed this little magic trick on successfully when I worked at Lockhart's.  The fuses can get a small amount of corrosion between them and the terminal on the fuse panel, causing the same basic symptoms as a faulty ground.
Good luck hunting.
« Reply #3 on: June 05, 2006, 01:55:18 PM »
I tied everything mentioned and haven't got it yet.I have brake lights and after I turn on the headlights then no more brake lights. Ill keep digging its got to be something really simple.
« Reply #4 on: June 05, 2006, 05:00:01 PM »
This may not apply in your case, but when I had problems similar to yours, the culprit was two wires touching each other in the tailight housing.  Once I made sure they didn't touch, they started working properly.  My problem was the brake lights being on while driving with the lights on and dimming when I applied the brakes.
« Reply #5 on: June 05, 2006, 05:07:05 PM »
I'll recheck it all again 3 more times :lol:  That sounds close bus,It might be a short after all.
