Topic: brake bleeding  (Read 9825 times)
Re: brake bleeding
« Reply #30 on: May 05, 2010, 04:45:31 PM »
fun
I think that this is the best photo I have ever seen of your beetle.
There is no duct tape in the photo at all.
Your membership in the triangle's country club might be at stake if you fix this correctly w/o using JB weld or such...
LOL
Re: brake bleeding
« Reply #31 on: May 05, 2010, 08:56:13 PM »
Thx Asbug,  To the untrained eye Stupie does look Un  triangle like. !st notice the old bike tire inner tube I use to keep the front door open,  Or the missing door trim,  I did not understand how the fasteners worked and threw out the little pins that I was supposed to push instead of discard.  The front is real low due to falling off the jack.   And dont forget how I reused the brake fluid.  I had my kid put the wheels on and forget to take the jack stands off the back swing arms.  So we had to re jack the vw,  remove the wheel , remove the stand  and remount the wheel etc......Oh I also had a red ramp under the exhaust pipe and when i lowered the car the exhaust bent up.  There's more but I dont want to embarrass myself.   Sc
Re: brake bleeding
« Reply #32 on: May 05, 2010, 10:13:55 PM »
A few days ago you were posting stuff about making brake fluid from brown sugar . . . What could you possibly admit to that would be "embarrassing"!?   ???
Re: brake bleeding
« Reply #33 on: May 06, 2010, 12:12:54 AM »
Brown sugar?   If you pumped it real fast would it make "Triangle Rum" ?
Re: brake bleeding
« Reply #34 on: May 06, 2010, 10:55:48 AM »
Seconded....
