Topic: Bosch Regulator part #???  (Read 3018 times)
« on: December 07, 2004, 07:38:11 AM »
I finally come to the conclusion that 99% of my electrical problems with Homer have been caused by the steady diet of AutoZone voltage regulators I've been bolting on it for the past 3 years.  I've trashed at least 3 generators 2 starters and I've never had a battery last more than 7 months.  I've replaced the regulator several times, but I'm thinking now that these things are bad right out of the box.  My battery is currently charging to about 10.5 - 11 volts and at night the lights surge from bright to dim on a pretty fast pace.  I need to get a new regulator ASAP and I don't want to buy another piece of crap from AutoZone.
The other night at the Ringgold Parade, Fielding told me I needed to get a Bosch solid state regulator.  I didn't even know there was a solid state regulator avalible!  I've looked at all the mail-order places and all I can find there is the mechanical regulators.   Feilding said that Al Johnson's VW in Dalton carried them, but I work the same hours as their parts department.  Does anyone know the Bosch part number for this regulator?  Maybe if I had the part number I could order it from one of my local parts stores or find it on-line somewhere.
« Reply #1 on: December 07, 2004, 08:36:21 AM »
Zen, I can not belive you of all people would use a reg.  or anything electrical from Auto-Zone for a VW. I can`t count the number of  good  gen. that were fried on the count of those reg.  Bosch has superceded the old faithful 12 v reg as we knew it . It now looks a lot like a reg for a alt. Jim Lockhart has used a few of these and says they are OK so far.
   Zen, I would look very close at your ground strap (tranny to frame) seeing you are having a low voltage and a slow starting problem all the time. It may seem tight , but I would clean the connections good. VW electrical systems don`t act like normal systems most of the time.
   I once saw a single filiment bulb installed in a double filiment socket in the right front turn signal on a van and all the dash lights would try to blink and the engine would stumble in rhythm. Go figure.
         Bosch.Bosch,Bosch !!!!!!!!! :lol:
« Reply #2 on: December 09, 2004, 01:47:23 AM »
I know, I know.  If anyone ever ask, I always tell them to buy a Bosch regulator . . . but seems like every time I need one, I need it NOW . . . and autozone is right around the corner and their $19 regulator will get me by for a few days until I can get a Bosch.  When I bolt it on everything is fine . . . so I don't think anything else about it UNTIL a couple of months later when that one craps out on me at the worst possible time . . . I gotta get it going right now . . . AutoZone is right around the corner and their $19 regulator will get me by until I can pick up a Bosch somewhere . . . but everything is working fine for now so I forget about it again until . . .
It's kind'a like the Yogi Berra quote I have in my signature line.  "In theory, there is no difference between theory and practice.  In practice there is."  Some theories just don't hold up in practice.
Take for instance, my theory on gas.  My theory is that you must have gas to run the engine.  Therefore, if the engine is running you have gas.  If you have gas, you don't "need" gas.  In theory that's true.  In practice, when you "need" gas, you can't drive to the pump to get it . . . but then with a little practice you can, from time to time, coast to the pump when you "need" gas.   But that's another story.  Back to the electrical issue . . .
I've replaced the battery to frame ground strap recently.  I've cleaned and tightened the connectors on the frame to tranny groundstrap recently.  The starter is a new Bosch unit I installed a few months ago.  The battery is about 3 months old.  The coil is Bosch.  The points, condensor, distributor cap, rotor button are fairly new Bosch (came in a brand new 009 I stuck in it recently)  OK, everybody give me heck about that too . . . I preach to everyone who will listen that the 009 isn't really that good.  A stock distributor with both vacuum and mechanical advance will usually perform better . . . but I'm a cheapo . . . got the 009 on sale for $45 with free shipping . . . when you add up the cost for a set of Bosch points, a distributor cap and a rotor button, the 009 is REALLY cheap.  And it will work OK.  In other words . . . "Take my advice . . . I'm not using it."  ANYWAY . . . back to Homer's electrical system . . .
Besides the starting and charging issues, Homer has more than his share of other electrical problems.  The insulation on most of the original wiring under the dash has melted and rehardened at some point in time.  A previous owner installed a universal aftermarket ignition switch in the dash and ran a new wire from the switch to the starter.  For the first year or two I drove him, it was a regular occurance for the generator light to come on and smoke start seeping from under the gages.  I could reach under the dash and shake the wires around a little and it would stop.  The last time I remember it doing that was when we headed home from Florida Bug Jam 2003 . . . so it's been over a year . . . guess I finally shook the wires into the right place.  'Cept now if I turn on the emergency flashers and then turn the switch off, the engine will keep running until I turn the flashers off.    :whistle:
« Reply #3 on: December 09, 2004, 08:35:42 AM »
I wonder if Yogi owned a VW van sometime in his career ? If so,Now I know that the term " Theory and  practice" really means you had a wiring diagram and used it.  "Practice and Theory" really means you didn`t use the diagram and are now theorising (?) how come when I connected that big red wire to that little brown wire, things got interesting. :-k
« Reply #4 on: December 18, 2004, 09:38:12 AM »
One day last week I got off early and got over to Al Johnson's VW.  They had the regulator in stock . . . set me back $33 and some change.  I installed it in the parking lot at the dealership and then drove up to Herb's house.  When I left the dealership my battery voltage was at 10.5, when I got to Herb's it was at 13.2.  I haven't had a problem starting Homer since!
The next time you have any sign of trouble with your generator powered electriclal system, get you one of these solid state BOSCH regulators!
« Reply #5 on: December 18, 2004, 11:22:19 AM »
Well Now !!!   You have entered the world of Bosch. Pay the extra $$ and be done with it. How much money have you spent on regs and batterys ? I bet it was more than $33.00. :roll:
