Topic: Ball joint replacement on a Supersonic beetle  (Read 17875 times)
« Reply #45 on: March 22, 2009, 09:36:37 PM »
Question,  why does the super beetle have that
heavy steel 90 degree angle piece.  Is a place to jack the car up?   Seems like its added weight.  What is its purpose?
« Reply #46 on: March 22, 2009, 09:53:42 PM »
Try a bit more specific.... what 90 degree angle pice?  can you get a pic of it?
« Reply #47 on: March 23, 2009, 07:01:40 PM »
The sway bar   goes through  the swing arm.   then a big 90  angle of steel  then a bolt    SC
« Reply #48 on: March 23, 2009, 09:13:59 PM »
honestly, wasn't ringing any bells, so i broke out the factory manual, and don't see what you are talking about.  everything i remember and see, the sway bar goes through a bushing located in the control arm, an is capped off with a washer and locking nut.  Picture?
« Reply #49 on: March 23, 2009, 09:44:08 PM »
Yes   we are zeroing in.   the sway bar goes through the control arm  but on stupie there is a 90 degree metal angle  instead of a lock washer.  Its like 3 inches square.    Maybe the later supers had a less robust design or maybe vw had some left over steel  when the made the 71's.
« Reply #50 on: March 23, 2009, 09:52:55 PM »
Or maybe another you (shudder) just stuck that on there because they couldn't find the darned washer they just took off..... :lol:
