Topic: anybody help with wiring the rail  (Read 2241 times)
Offline bubbz
  • Life is good!!
« on: March 04, 2010, 09:49:21 PM »
 ??? Im going to try my luck at running new wire on the rail. Ive heard that i need a dummy light for the gen.. Anybody got a diagram (for dummies) or link, or how-to..
Re: anybody help with wiring the rail
« Reply #1 on: March 06, 2010, 06:50:58 AM »
Run positive power to the light unswitched (but run it through a fuse of course).  Run a wire from the idiot light terminal on the regulator (#61 if I remember correctly) to the idiot light.  That's the light's ground circuit.  The ground is switched on and off inside the regulator to turn the light on or off.
Offline bubbz
  • Life is good!!
« Reply #2 on: March 07, 2010, 10:44:49 AM »
I was out there till 1:00 this morning wiring it and didnt evev here the thing turn over  ..
« Reply #3 on: March 07, 2010, 11:49:35 AM »
alright, I got it wired.. but i think my motor has a 6v flywheel!?! the starter does all it can do but dont reach the flywheel????????
I could be wrong here, but I think the starter ring is at the same depth on both the 6 volt and 12 volt flywheels.  The differance is the diameter and number of teeth.  I think if the flywheel and starter are mis-matched either way, contact will be made but it will grind.
Offline bubbz
  • Life is good!!
« Reply #4 on: March 07, 2010, 12:00:39 PM »
After further inspection .. The starter seemed to work fine. its an autostick starter.
Its not hitting anything but i noticed the bellhousing is 10mm deeper on this one than the one with early style t/o bearing.. is there a special starter for it????
« Last Edit: March 07, 2010, 01:53:38 PM by bubbz »
Offline bubbz
  • Life is good!!
« Reply #5 on: March 07, 2010, 07:07:59 PM »
ok! the trans is late bus.. I got an early bus trans. can i change throwout forks and use early bellhousing or ???  if so how the *#%$ do i get the arm out?
Offline attack chicken
  • Ooltewah
« Reply #6 on: March 07, 2010, 10:25:37 PM »
You could just use a late bus starter..I have a used 1...would trade for your auto starter as i can't use it in the bellhousing I have for ground hopping engines...even have a new bushing for the nose.
Offline bubbz
  • Life is good!!
« Reply #7 on: March 07, 2010, 10:41:31 PM »
sounds good to me.. I'll run by the shop tomorrow if i get time..
Offline bubbz
  • Life is good!!
« Reply #8 on: March 08, 2010, 10:02:18 PM »
thanks Rick Im going to put the starter on tomorrow. Hoping to get this thing at least running by april...
Offline bubbz
  • Life is good!!
« Reply #9 on: March 09, 2010, 08:44:04 PM »
Thanks everybody.. I got it started.. runs real good so far.. Just need to fix up my fuel lines and look into checking valves for proper adjustment and new cover gaskets..
