Topic: Alternate Horn Wiring Scheme  (Read 2289 times)
Offline rokemester
« on: July 18, 2009, 09:43:17 AM »
I've gone through the entire horn wiring circuit on my 66 Bug but I'm still getting a feeble start of a honk. Does anyone have an alternate wiring scheme that can bypass the funky horn column ground circuit?
« Reply #1 on: July 18, 2009, 10:39:47 AM »
Do you know if your horn OK ?    Sometimes we would peck on the horn with a hammer while someone held the horn button down.  Worked sometimes.
    The horn has voltage through it when the ing. switch is on.  You can take a test light or meter and see if you have current on both term. on  the horn. If you do ,find out which wire is the "hot" wire and then pull the ground wire off. Take jumper wire and put it on the horn then to a good ground. Bumper ? Are you still 6volt ?  If you have current to the horn but not out form  the horn,
 its bad
Offline rokemester
« Reply #2 on: July 18, 2009, 02:54:59 PM »
Yeah the horn is fine I tested as you described. I've really cleaned all the trouble spots on the grounding circuit, but still just getting a week horn blip. Someone has suggested a 6v horn relay, but they are a bit hard to come by.
« Reply #3 on: July 18, 2009, 05:31:16 PM »
How about the wire behind the horn button that attaches to the horn ring ?
    You can unscrew the wire and ground it to a good ground and if it works.
   Did you find the "push on "  connector at the bottom of the steering shaft housing right over the master cyl. and the wire coming out of the shaft jumping over to the rubber disc  ?   I have had a lot of trouble with the one on the disc before. You can loosen the bolt/nut on the disc where the connector is  and clean really good.
Offline rokemester
« Reply #4 on: July 19, 2009, 12:57:19 PM »
All great suggestions and I have cleaned every one of the contacts as you have described. The one contact that I suspect the most is the one at the top of the steering tube on the sleeve with a terminal riveted to the sleeve. I've tried to clean it up, but there is corrosion entirely around that sleeve and it's very difficult to get into every nook and cranny.
« Reply #5 on: July 19, 2009, 07:34:59 PM »
Anytime I start to work on VW horn, I go to link below, scroll down to the electrical section and click on "Horn Wiring Hell; How to survive it"
http://www.thebugshop.org/bsfqindx.htm
Even if you already understand the circuit and have a wiring diagram, it's a good refresher.
Offline rokemester
« Reply #6 on: July 19, 2009, 10:49:48 PM »
Thanks I've seen this cited before in other Horn trouble threads. I forgot that the author goes through other VW issues...VERY helpful. This is a great forum and VW club.
