Topic: air adjustment on the carb  (Read 2283 times)
Offline eakanator
  • Rome, Ga
« on: November 22, 2004, 09:02:26 AM »
After two months at body shop, got the bug back Saturday. Even though it starts great and ran decent home, noticed at idle speed the engine is  rocking and there was a little black smoke.  Wondering if the air adjustment screw somehow got turned( covering the engine to make sure no sand, paint got in the engine, re-installing the decklid, etc ).  If I'm going to adjust the screw, this is the one I need to adjust, correct? Or is there anyting other reason it might start acting like this.  David re-built it and it had always ran great. Just want to be careful before I start adjusting stuff.
Ron
« Reply #1 on: November 22, 2004, 04:49:22 PM »
Ron, Make  sure the choke came off ok . If so ,the small adj screw on the lower left is what you deal with.  With the engine at idle, screw it out and see if it helps. You could check the pilot jet on the right side of the carb and make sure its tight.(the little brass thing) You could have pick up some trash in this little jet. Take it out and blow it out. Let me know.
