Topic: 6v Options - need some  (Read 6360 times)
« on: December 03, 2001, 02:23:34 PM »
Hey all, has anyone got any suggestions as to what I can do for a radio/speaker(s) and possibly foglights in a 6v car?
Zen has had some helpful hints as to what to do to convert it and I will probably try sometime next year when the show season starts back up again and I can get ahold of the number of parts I will need but for the mean time what can I do for more light and maybe a little bit of sound?
« Reply #1 on: December 03, 2001, 07:39:27 PM »
Bring it home son and I'll convert it to 12v :)
« Reply #2 on: December 04, 2001, 01:33:24 AM »
I wouldn't fall for it Travis, he just wants his Type 3 back. :biggrin:
rgj
« Reply #3 on: December 04, 2001, 08:54:02 AM »
Yeah, I've heard that one before....I was born at night but not LAST night ;)
 :p
« Reply #4 on: December 04, 2001, 09:24:09 AM »
Hey Travis,
I found a couple of places on the net that sell 8 Volt batteries . . . but after reading several post on converting 6 Volt tractors to 8 Volt, I don't really think this is the way to go . . . Seems that down the road it causes way too many problems.  (For those of you just getting in on this conversation, I had told Travis on another forum that I had an uncle who put an 8 Volt battery in an old Ford farm tractor and left everything . . . lights, starter, ingnition, etc. 6 Volt . . . he must have adjusted the voltage regulator up to over 8 volts to keep it charged, but other than light blubs having a shortened life, everything seemed to work much better).  Anyway, forget I told you anything about the "8 Volt cure."  Sounds like it's more trouble than it's worth.  :lookaround:
Again, Travis and I have already discussed this, but for the benifit of anyone else who might be having dim light problems on a 6 volt car I'll say it again . . . If you want to brighten the lights while it's still 6 volt, clean and tighten each connector in the wiring harness.  Use a small wire brush or a stiff toothbrush remove each connector, brush out all of the corrosion from the spade and push on connector, then squeeze the push on part together just a little so that it's very snug when you push it back on the spade.  Put a dab of dielectric (spelling?) grease on the connection to prevent moisture in the air from causing future corrosion.  Replace any bad connectors . . . use solder connectors and heat shrink tubing for the best result, crimp on connectors don't always make a connection that will hold up.  Don't neglect the fuses!  I'd go ahead and remove them, clean the connectors and put NEW fuses back in (ends coated with grease!).  If you want to see what effect corrosion can have on your system, take a car that has not had the fuse touched in years, turn the lights on at night and then wiggle the fuses . . . I'll bet money that they brighten up a little once you break out all the corrosion from the connector!
:music: As for some tunes, your probably stuck with a stock 6 volt AM unit.  Unless you want to try one of those 6 volt to 12 volt inverters and install a 12 volt sound system . . . by the way, I have one of those that came in my 63 bug.  I've installed a 6 volt radio and I have no idea if this thing works . . . but if you want to try it, you're welcome to it. :music:
OK, everyone else . . . jump in here!  I've got a 63 bug that I'm keeping 6 volt.  What I've posted is mostly stuff I've picked up from listening to some "old timers" who delt with 6 volt for years.  I don't claim to know it all, and I want to learn every to keeping a 6 volt system in top notch condition that I can!
 :alien:
Edited By Zen on Dec. 07 2001 at 09:06
Offline letsbuggy
  • georgia
« Reply #5 on: December 06, 2001, 09:57:40 PM »
not sure where to find them   but have heard that they have came out with a split battery to where the only converting is to change your lights and raido to 12v and the rest is 6v
« Reply #6 on: December 08, 2001, 09:32:12 AM »
Thanks Letsbuggy, I found that battery actually, it is available through "My Classic Car (.com)" but you have to convert your charging over to 12v, which is the biggest stumbling block I have, I don't mind having to change out the bulbs or accessories and the starter will apparently live for quite some time before giving up the ghost.
To change out the charging system I have to find a later fan shroud, get a later generator or alternator, but I'm not sure about the alternator's fitting?!  As an alternative, someone wrote me that I could get a Porsche 356 12v Generator, which is a direct replacement for my 6v, in size and mounting.  I checked on price and availablility for said Generator......you don't want to know, Santa can't afford to be that good to me ;)
Trav
« Reply #7 on: December 08, 2001, 01:39:01 PM »
Seems like there should be some way to set up two 6 volt batteries in the system and charge them on a parallel circuit with the 6 volt generator, but somehow have an isolated 12 volt circuit using them in series . . .
It's been years, but my dad was desiel mechanic when I was growing up . . . doesn't a big rig have multiple 12 volt batteries and a 12 volt charging system, but has a 24 volt starter?  If so, that same principle could be used and change your lights and radio off of 12 volts and leave every thing else 6 volt.
Or, what about having the generator rewound for 12 volts?  Of course that might cost more the Porche generator . . .  :confused:
Offline letsbuggy
  • georgia
« Reply #8 on: December 10, 2001, 08:15:23 PM »
the shroud is no problem i just hapen to have a doner ready fore the trash
Anonymous
« Reply #9 on: December 13, 2001, 10:20:01 PM »
Hey Travis the eazyist way to get the results of music in the T3 is to buy about 6 or so D batteries and get a boombox. HEE HEE HEE
