Topic: 6 volt regulator output  (Read 4587 times)
Offline Got Bug ?
  • Chattanooga, Tn
« on: October 30, 2015, 11:43:54 PM »
I am still struggling with my '63 and it's 6 volt lights. I have done several things to make them a bit brighter but still not to my liking. I have cleaned connections, added a ground wire, replaced ground cables...that sort of thing.
I saw a method of bending a tab in the regulator to increase the output a little but am very cautious about anything electrical...that's not something I'm good at.
Across the battery I get a little over 6 volts without the engine running. With the engine running and reving up slightly, I get about 6.4 volts. I'd like to adjust the regulator and see about 7 volts...seems like that would help the lights and the battery.
Has anyone ever tried this method of bending the stop in the regulator ?
Re: 6 volt regulator output
« Reply #1 on: October 31, 2015, 03:42:39 PM »
Never tried that,  I've always heard 8 volt tractor battery, mine would hardly turn over outside in the winter
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #2 on: October 31, 2015, 09:12:56 PM »
So how do you keep the 8 volt battery charged ?
« Reply #3 on: November 02, 2015, 08:49:14 AM »
Never got that far
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #4 on: November 02, 2015, 09:09:36 PM »
Yeah, me too. I've seen an 8 volt battery many, many years ago. If I could get another volt out of my regulator it sure would help. I tested the generator and it turned out sufficient voltage, so I think the regulator is the problem. I tried another regulator with the same result. I may bend the contact in one of them and give it a try. I'm just too lazy to do it right now.
