Topic: 6 volt charging system  (Read 6961 times)
« on: April 27, 2009, 06:40:15 AM »
My 62 Beetle is having charging issues,  i researched several manuals and the internet and most of the info is on testing 12 volt systems, with the d+ and df labeled on the generator,  mine just has the 2 wires straight to the voltage regulator.  The warning light used to run dim,  then it ran bright, and then no light.  We tinkered with it this weekend, tapping on the regulator cuased the light to be bright for as few seconds then went out agian.  I could not find the odb 2 diag port so i need help!
« Reply #1 on: April 27, 2009, 07:23:58 AM »
Not sure of the answer but sounds like you need a reg,ask Rick about it.
You can also buy an 8v batery and that will help cure your 6volt woes as well.
« Reply #2 on: April 27, 2009, 08:20:49 AM »
I would bet on a reg also. We also had a problem with the head light switch causing a dim glow day and night. Some of those early 6 V system ran the main wire (red) from the rear to dash and connected to the light switch then back to the fuse panel. One of the early fixes was to put the main red wire directly to the fuse panel then pig tail it to the switch . Sounds weird but it worked. Feel and see if the switch gets really warm  with the lights on.
     When you said no light ,did you mean it didn't come on running or not ? The blue wire off the reg. is your warning light. You can also put a volt meter to the terminal with the blue wire to check output . You need about 7.2 to work.
      I not sure what you mean "odb diag port".
« Reply #3 on: April 27, 2009, 10:16:49 AM »
meant obd 2
« Reply #4 on: April 27, 2009, 10:36:29 AM »
Dang Travis, You could have said  "obd 32 and I still don't what you are talking about.  You have to remember that my formal factory schooling stopped in 1972. The only thing I remember is " B.Y.O.B :lol:  :lol:
« Reply #5 on: April 27, 2009, 12:18:20 PM »
obd 2 is the operating system on 1996 and new computer diag langauge,  i get so used to hooking a car to a computer i forget about the old school was.
« Reply #6 on: April 27, 2009, 02:06:56 PM »
Kickin it diagnostic like in the old school ways.  we are kinda spoiled now.  I'll take this stuff over CIS any old day. 8)
« Reply #7 on: April 27, 2009, 03:03:50 PM »
There is no output, 6.2 volts and does not increase with rpm, i've read about undoing the vr and test the gen. only by grounding 1 wire, but i wasn't sure which one on the 6 volt gen.
« Reply #8 on: April 27, 2009, 04:20:37 PM »
Hell Fire !! CIS is still new stuff,    but any good MECHANIC can understand it.
   You need a degree from MIT just to open the hood and replace some little $1200 "Flapping Thing" Thats what a TECHNICIAN learns to do.
   Travis , I can't remember which wire to check but you  can take the belt off and run a jumper wire from the + (30) on the reg to the blue (light) "push on connector "  The gen. should start motoring if the gen is OK. You may or may not need to spin the gen by hand to get started. If it turns into a motor, I would try a Reg.  This is a trick we use to do at the dealer when the shop forman wasn't looking to help cool off the engine to adjust the valves. :lol:
« Reply #9 on: April 27, 2009, 04:42:49 PM »
Don't you just love the "tricks"
« Reply #10 on: April 27, 2009, 05:26:44 PM »
You Betcha,   Don't forget I use to be a "Flat-Rate" Mech.  for about 45 years.   Time is money and this was the only way you could make a living when the labor rate at the dealer was $5.00 a hour but I had bought a house, had a new baby boy and a new '64 Beetle. Boy have times change
 :lol:  :lol:  :lol:
« Reply #11 on: April 27, 2009, 05:33:20 PM »
Was the baby boy Scott?....
Offline Bugthug
« Reply #12 on: April 27, 2009, 07:03:06 PM »
I'm having problems with my 6 volt gen. too. Not as bad as Travis' though. My bearings are bad but it's still charging and it's got a new regulator on it. It keeps my battery hot as a firecracker but it's getting noisy. Is there a 6 volt alternator conversion? If so, is it with a built-in regulator? Is it as pricey as I would think? Would it be better to convert to 12 volt? To do that, do you have to change the starter? Will a 12 volt starter bolt right up? By the way, what's the trick to getting the fan pully to act right when you go back on with the belt. I kept having problems with the nut tightening down waaay before the belt was tight enough. I left the shims alone and had the inner slots lined up. I finally just sort of "lucked out" when I got the pulley to pull together. The belt is pretty hard and cracky, by cracky. Too many stupid questions, Retired?
« Reply #13 on: April 27, 2009, 07:11:36 PM »
Think of all the 6 volt stuff I tossed out a few months back...........I asked and nobody wanted it?????  :?
« Reply #14 on: April 27, 2009, 07:14:06 PM »
I order a gen and regulator used of the internet, if need be we can use one or parts from one to fix yours,  i am about to do some more testing on mine, 4 days till circle yer wagens!
