Topic: 46mm rear axle nut  (Read 3107 times)
46mm rear axle nut
« on: January 31, 2007, 02:13:22 PM »
I have a 46mm rear axle nut seized.  A 440ft/lb impact wrench wouldn't budge it.  Any suggestions?
46mm rear axle nut
« Reply #1 on: January 31, 2007, 02:42:14 PM »
Somebody smarter will answer soon...till then they make a tool for that it fits on and you beat the snot outta it. Most folks call it a rear axle nut whacker,go figure.
46mm rear axle nut
« Reply #2 on: January 31, 2007, 04:38:56 PM »
Is this a electric impact wrench? If so forget it. If it will not come off with a real AIR wrench (3/4 inch) with some air behind it? Snap-on use to make a "hammer wrench" (like Scott said) about 1-1/2 feet long. About 2 good licks with a slege hammer off it would come. I had one until it was stolen a few years ago. You could split the nut with a air chisel as a last resort. Soak it down with some PB Blaster no matter what you use. A little heat wouldn't hurt either.
    I'm talking about a real compressor and not a little roll- around.
Gehackt
46mm rear axle nut
« Reply #3 on: February 01, 2007, 08:58:52 PM »
Soak it in PB Blaster, mapp gas heat and an impact gun!! Hasn't failed me yet.
46mm rear axle nut
« Reply #4 on: February 01, 2007, 10:07:26 PM »
if all else fails... use a very large nut splitter
46mm rear axle nut
« Reply #5 on: February 01, 2007, 10:47:35 PM »
Hey Brian, I've got one of those 46mm nut whacker thingies (ouch) if you want to borrow it.
