Topic: 1977 Westfalia Tires  (Read 4325 times)
Offline Ruttco
« on: March 03, 2009, 09:08:04 AM »
I need to put tires on my son's bus this weekend. First of all where can I get the right tires at a good price. Second, are they open on the weekends? Thanks in advance.
« Reply #1 on: March 03, 2009, 09:34:33 AM »
I think it's unlikely you'll find any place locally that would have correct bus tires in stock. You need reinforced sidewall 185R14 tires with at least a 'C' load range for proper handling, safety, and to support the weight of the vehicle. LRD would be even better.
Continental Vanco 8s are a good choice, Continental is a German manufacturer and OEM supplier of tires to VW to this day. Yokohama Y356 also fits, that's what I have on my bus but they are not all season tires. Hankook RA08 is also supposed to be a good bus tire. All of these run about $75 per tire I think.
I would probably order a set of tires online from Tire Rack or Bus Depot and have them mounted/balanced locally. Do not let a shop talk you into purchasing passenger tires for your bus. They will not support the weight and it will handle like crap.
Offline Ruttco
Bus tires
« Reply #2 on: March 03, 2009, 09:40:13 AM »
Thanks Russ. What about that shop out on Hwy. 58? Or would it just be cheaper for me to order them?
« Reply #3 on: March 03, 2009, 09:45:43 AM »
R&M Automotive? Give Rick a call. Maybe he can order some for you and I'm sure he could mount them. He wouldn't sell you the wrong tires.
Offline Ruttco
« Reply #4 on: March 03, 2009, 09:47:44 AM »
« Reply #5 on: March 03, 2009, 09:54:20 AM »
Russ, the link you posted for R&M brings up a San Francisco business.
« Reply #6 on: March 03, 2009, 09:56:23 AM »
Here is the correct link:  http://www.randmautomotiverepair.com/
Re: 1977 Westfalia Tires
« Reply #7 on: March 03, 2009, 10:04:57 AM »
Quote from: "Ruttco"
What about these? They have a D load rating.
http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=Vanco+2&partnum=8QR4V2&vehicleSearch=false&fromCompare1=yes&place=0
Those would work, I think Vanco 2 are newer than Vanco 8s actually. They are summer tires like my Yokohamas.
« Reply #8 on: March 03, 2009, 10:05:14 AM »
Quote from: "jrcnova"
Ok I fixed the link. Thanks.
« Reply #9 on: March 03, 2009, 11:04:06 AM »
Quote from: "Russ"
The 8 in Vanco 8 refers to the 8 ply sidewall.  If that is a correct correlation. Then Vanco 2 would only be 2 ply and would not be reinforced.
« Reply #10 on: March 03, 2009, 11:05:43 AM »
Oh, in that case you don't want them. Didn't know about that.
« Reply #11 on: March 03, 2009, 11:22:05 AM »
Offline Ruttco
« Reply #12 on: March 03, 2009, 11:22:54 AM »
Everything I can find about the "D" rating states that it is an 8ply tire.
Offline Ruttco
« Reply #13 on: March 03, 2009, 11:24:19 AM »
« Reply #14 on: March 03, 2009, 11:42:00 AM »
One thing that concerns me is that it mentions the Vanco 2s are designed for today's van that drives more like a passanger car.
