Topic: 1967 VW beete low power? overheating??  (Read 2308 times)
Offline kevingabor
« on: July 01, 2012, 03:35:08 PM »
1967 beetle.  just joined the club and just got my VW in mid May.  Concerned it might be overheating- oil dip stick is just barely to hot to hold after warming up.  Car seems to have low power especially going up hills.  I think I need a good air cooled guy to give it a good once over.  Looking for some advice and direction for repairs/help.
Kevin
Re: 1967 VW beete low power? overheating??
« Reply #1 on: July 01, 2012, 05:20:39 PM »
First thing I'd check would be the points and timing.  Make sure the points are in good shape and gapped correctly, then set the timing at maximum advance to 32 degrees before top dead center.  If the timing is less than 32 degrees, you'll loose power and can overheat somewhat. If you have more than 32 degrees of advance you will gain a lot of power for a short time . . . right up to the point that you burn holes in the tops of the pistons.
Lots of other things can cause overheating.  A few things I've had experiance with include:  If the car sat for any length of time, anything from mice or dirt dobbers could have nested in shroud or fins and blocked the air flow . . . leaks in the intake can cause a lean fuel/air mixture, which will make it run hotter than normal . . . missing pieces of tin . . . a bad engine compartment seal letting hot air be pulled back into the engine compartment . . . lots of other stuff, those are just a few off the top of my head.
Offline Got Bug ?
  • Chattanooga, Tn
« Reply #2 on: July 01, 2012, 06:54:53 PM »
I had a friend who kept paper towels in his engine compartment to wipe the dipstick when he checked his oil level. They were constantly disappearing. One very hot day, with the engine NOT running, I reached in to see if his fan had maybe come loose and wasn't turning. I felt something soft and came out with a handful of paper towels that had been sucked into the fan until the air flow was blocked.
All he said was, "So that's where they're going!"
Offline kevingabor
« Reply #3 on: July 02, 2012, 07:02:59 AM »
ok- thanks for the advice- I will need to find a good reliable VW air cooled mechanic too
