Topic: 1600DP - New Motor  (Read 3459 times)
69slambug
1600DP - New Motor
« on: February 03, 2004, 03:50:21 PM »
My 69 bug has the original 1500cc and I am wanting to drop in a 1600.  Just needing to know a reliable source to purchase one of these enginges local, or someone to convert mine over and do a good dependable job?
1600DP - New Motor
« Reply #1 on: February 04, 2004, 12:16:08 AM »
About the only full time air-cooled vw mechanic left in the area is Jim Lockhart on Rossville Avenue.  I've met him . . . seems like he knows his stuff, but I've never had him do any work for me personally.  Some of our other members have and they might want to chime in here and give you some first hand feedback (and phone #).
If all you are wanting to do is change from a 1500 to 1600 and the bottom end of the engine is good, I recomend you do it yourself.  With just a little guidence this can be done in just a few hours for under $150.  If you need new heads, add about another $250.  If you need to split the case or you want to change from single port to dual port heads, it can get more involved and lots of folks will want to pay a pro to do the work . . . not a "bad" idea IF you have a lack of mechanical skill and a big budget.  With some guidance though, this can also be a do it yourself (and do it right) project.
You could also purchase a brand new 0 mile "crate" motor . . . around $1200 plus shipping.  Look in VW Trends or Hot VWs magizine and you'll find lots of mail order vendors that have them.
 :D
1600DP - New Motor
« Reply #2 on: February 05, 2004, 01:20:39 PM »
Jim built my bus motor.  It's been rock solid.
1600DP - New Motor
« Reply #3 on: February 06, 2004, 08:57:02 AM »
Bobby Hixson on Fairview Rd in Hixson is another excellent choice for a rebuilt engine. I would suggest you stay away from a LOT of the rebuilt engines advertised in our magazines. You have no idea what you are getting with these engines (for the most part). A lot of them are REAL PRETTY on the outside but what's on the inside might not be and probably isn't, quite so pretty.
Bobby is in the phone book.
        :cool:
1600DP - New Motor
« Reply #4 on: February 06, 2004, 08:17:42 PM »
Quote from: "vwherb"
Good advice!  GEX and Bernie Bergman are two places I've heard nothing but BAD stuff about.  Most of the others I've heard mixed reviews on . . . and more bad than good.
Just to clairfy what I was saying . . . if you buy it mailorder, buy a NEW, VW FACTORY BUILT engine.  If your going for a rebuild, either do it yourself or find a local mechanic with a good solid reputation for building air-cooled engines.  Just because the guy has built 10,000 small block Chevy's doesn't mean he can re-build a stock 1600.
