Tech. Center
Air-Cooled VW Tech
009 Dist
Topic: 009 Dist (Read 3246 times)
Bigdummy
Ft Worth , Texas
009 Dist
April 03, 2008, 05:57:57 PM »
Ok I have the 009 installed and the weber carb,and intake on now,but I forgot where the green wire on the dist goes? Silly me! Help! :oops: :roll: :roll: :roll: :roll: :roll: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Brian
009 Dist
April 03, 2008, 07:30:09 PM »
Negative side of Coil :wink:
Bigdummy
Ft Worth , Texas
009 Dist
April 03, 2008, 07:41:32 PM »
Ok , so the other 2 go on the pos. And the only wire from the dist goes on the neg side...correct?
Brian
009 Dist
April 03, 2008, 08:38:32 PM »
There is ususally 2 similar sized black wires that go on the positive that sometimes has a piggy back to the choke and Idle cut off on the carb. Then there is one more that goes to the oil pressure switch. There is also two heavier gauged wires that go to the Alt/Gen.
http://www.thesamba.com/vw/archives/info/wiring/bug_super_71.jpg
Bigdummy
Ft Worth , Texas
009 Dist
April 04, 2008, 07:40:45 AM »
Sweet ! Thanks Brian!Now I gotta get some stronger spring to pull linkage back......
Brian
009 Dist
April 04, 2008, 08:03:05 AM »
The 2 black wires are going to the #15 pole side of the Coil which is the + side. The green condenser wire is going to #1 pole which is the - side of the coil. The coil should have the numbers stamped on top next to the pole.
Brian
009 Dist
April 04, 2008, 08:15:09 AM »
Quote from: "Bigdummy"
Either I'm losing my mind or you totally changed your post. :-k
Bigdummy
Ft Worth , Texas
009 Dist
Reply #7 on:
April 04, 2008, 08:25:45 AM »
Who me!
:lol: :lol:
009 Dist
Reply #8 on:
April 04, 2008, 08:40:28 AM »
What size Weber are you using ? Are you talking about a Holley/Weber ?
Bigdummy
Ft Worth , Texas
009 Dist
Reply #9 on:
April 04, 2008, 06:05:36 PM »
Its a weber progressive 32/36 Dfav, Got it running jsutr need some adjustments , and a timing light to set the timing spot on.....Fred
Tech. Center
Air-Cooled VW Tech
009 Dist
