Topic: '72 Weekender, parts ordered, need advice  (Read 2151 times)
Offline vwstuart
« on: May 19, 2005, 06:18:17 PM »
Greetings,
     Today, I orderd a Time-Sert kit to repair the striped exhaust studs.  It will be several days before the kit get here, which should give me time to get some answers.
     I will have to drill and tap the existing stud holes to install the inserts.  The engine is out of the bus, but the heads are still attached.  What advice do you folks have for installing the inserts?  Shoud I remove the heads, turn the engine over with the heads attached?  Any advice about keeping the drill and tap straight, so the finished repair will be correct?
Stuart
« Reply #1 on: May 20, 2005, 10:13:54 AM »
If you have the oil drained , I think I would be tempted to "flop" the engine over being sure that you are not going damage anything and have enough help.  I would "stuff" some oil soaked rags in the ports or tape over them before drilling to catch all the metal particles. Some of the valves are going to be open and you don`t want that stuff to drop into the clyinders. Makes weird knocking noises and possibly locks up the engine. You need to tune up your eyeball as far as drilling straight. Its really not that hard to do. Just take your time.
   After all this said and done. !m assuming that everything else other than the studs are OK ?
