Topic: Removing a 98 Jetta 5 Speed Transmission  (Read 8951 times)
Re: Removing a 98 Jetta 5 Speed Transmission
« Reply #15 on: February 13, 2016, 12:44:47 PM »
Support engine from above
- Check
Remove rear trans mount from transmission and subframe.
- Check
Loosen all bolts from engine including starter
- Starter is off
Remove drivers axle from car.
- Check
Remove passenger axle from transmission flange only.
  - Check
Use widow maker jack in between subframe and motor to push it toward the radiator about 2".
- Used a 5 foot pry bar, but moved it . . .
Remove small dust cover above passenger side axle (10mm bolt)
- Not sure about this.  I don't see a dust cover.  It had new axles installed recently, could the dust cover have been left off?  There's a thin shield behind the flywheel . . . I don't see what's holding it.  Looks like all the bolts are out and the only thing keeping it from coming out is the dowel pins, but it feels like something is still holding it.
Now grab the transmission and push the differential up so that you can pivot the trans around the flywheel and toward the the radiator.
- Do the engine and transmission need to be close when I do this?  Maybe I have them too far apart and I can't get it to clear the flywheel.
Now it should fall on your face.
- Hasn't yet, but I'm still working on it!
[/quote]
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #16 on: February 13, 2016, 01:47:46 PM »
The dust shield behind the flywheel has a removable flap that's about the size of a pear. It could be missing. It's very common if the clutch has been changed.
Once you are off of the dowels you should be able to start rotating the trans.
Give me a call or send me a text. I don't have anywhere to be until 4.
Sal
4234211496
« Reply #17 on: February 13, 2016, 03:04:07 PM »
FREE AT LAST! FREE AT LAST! THANK . . . crap.  OK, got it free, but on the way to falling on my face, I let it rotate back and the flange dropped behind the starter ring gear teeth . . . the other flange is against the motor mount.  My jack sucks.  35 years ago I could have gotten under it and bench pressed it up and maneuvered it out . . . Break time.  I'll get it.  It's a matter of pride now.   :P
« Reply #18 on: February 14, 2016, 12:34:56 AM »
OK, I found the dust shield in question . . . it would have nice if I would have figured out what it was and how it was held on before it got a 90 degree bend in it, but no damage a big hammer can't fix.  I had to buy a second cherry picker and had one under the front of the car holding the engine and the second one under the side of the car with one of the outriggers off the ground (that makes for a really unstable cherry picker by the way) and a small floor jack under the transmission, but I finally got it unjammed, raised it back up into place and took it out correctly.  It wasn't that bad with the dust shield gone and the help of the extra cherry picker.  The hardest part was trying to operate a floor jack under the car and a cherry picker beside  the car while I was standing in front of the car.  It would have helped if was double jointed in my right shoulder and elbow.  I may be now.  But, victory is mine!  With the last few rays of sunshine, I drug the transmission from under the car an made a photo of it.  Looking back at the photo, it may have been after the last few rays of sunshine . . . either way, it's out.
Now . . . I've got to start re-assembling Jetta #2.  Wooo Hooo!!!   ::)
Offline DieselDoc
  • Chickamauga, GA
    • S&P Automotive
« Reply #19 on: February 14, 2016, 12:15:19 PM »
Good gravy biscuits!!
Glad you got it out.
« Reply #20 on: February 14, 2016, 12:25:13 PM »
Oh that's what you were trying to get? I have one sitting next to your 2.8 in my driveway!
« Reply #21 on: February 14, 2016, 12:45:36 PM »
. . . but yours is upside down.   ::)
« Reply #22 on: March 06, 2016, 06:44:32 PM »
I'd like the meet the German engineer who designed the flywheel/clutch/pressure plate set-up in this thing.  I'd give him a swift kick in the seat of his pants.  Why keep it simple when you can flip it around backwards and make it work.  Engineering for the sake of engineering.  After I finally located the correct socket to remove it, I found out the old clutch disc was almost to the rivets.  So instead of making progress today while Jesse was here to work on it, I got to order a clutch "kit" and wait . . .
Oh well, I didn't really want to work on it today anyway.   ;)
