Topic: Mark would call it a breakdown, I call it an incident...  (Read 8000 times)
Offline green1
  • Always on the road.....
« on: June 14, 2011, 10:35:27 PM »
I left work today just like I always do and while shifting from third to forth, suddenly I couldn't get it into forth or any other gear for that matter.  I cruised to the side of Amnicola and it wouldn't go into any gear.  I turned the car off and was able to restart it without pushing the clutch pedal in.  I turned it off again and got into gear.  From first, it jerked a few feet and then I shifted to second.  After that it ran fine, but it was concerning.  I got home to Signal with no more problems, but now I'm a little nervous about being on a major road.
Anybody have any ideas or can tell me that if we ignore it, it will heal and go away?  We're on a tight budget right now, so I'm praying it's something easy, or theres always that ignoring plan.... :P
Re: Mark would call it a breakdown, I call it an incident...
« Reply #1 on: June 15, 2011, 07:00:38 AM »
with out looking at it or driving it, it kinda sounds like a clutch slave cylinder going bad,  also i have seen part of the clutch come apart and cuase a problem
Offline green1
« Reply #2 on: June 15, 2011, 08:08:44 AM »
Forgot to mention that since I bought the car, it's been difficult to shift into 1st gear from neutral.  It goes in just fine from 2nd, so it became habit.  It's not that it would never go into 1st from neutral, but it was very difficult so I used the path of least resistance.
Does this sound like the warning symptom, or a separate issue?
It drove just fine this morning, but the pedals seem a little stiffer than I'm used to.  Someone else wouldn't notice it but I do.
« Reply #3 on: June 15, 2011, 08:16:43 AM »
i could also be the clutch or throw out bearing sticking,  or cables out of adjustment
Offline green1
« Reply #4 on: June 15, 2011, 08:51:30 AM »
cost-wise, what would be a gross worst-case estimate?
« Reply #5 on: June 15, 2011, 09:37:51 AM »
you could be looking at 800 or more if the trans has to come out,  2-300 for the clutch slave, you really need to pin down the problem first,  all the time poeple fear the worst and it could be someting simple like a bushing or a hose, or a rock rolling around on top of the transmisson
Offline green1
« Reply #6 on: June 15, 2011, 09:40:23 AM »
fingers are crossed for the rock option!   :P
« Reply #7 on: June 15, 2011, 04:49:55 PM »
THIS IS AN EARLY MODEL CABRIO......
There are no cables to adjust, but mechanical linkage for shifting....
And, there is no slave cylinder... the clutch is mechanical, using a self-adjusting cable.
Probably a boogered up/ broken shift linkage piece or broken bushing.
Settle down people... probably won't be that bad.   ;D
Is the shifter feeling kinda loose by any chance?
Offline green1
« Reply #8 on: June 15, 2011, 04:56:44 PM »
I actually took it to be looked at today at lunch.  The verdict was a new clutch and bushings for the shifter since it will all be taken apart anyway and they're shot.
"GRAND" total was $1100.  Gonna be tough since we're up to our eyeballs in roof work on the house.  Timing sucks.
« Reply #9 on: June 15, 2011, 05:47:20 PM »
did you get a second opinion? Where is that? It sounds like an awful lot!
Offline attack chicken
  • Ooltewah
« Reply #10 on: June 15, 2011, 06:11:18 PM »
It was us.  The shift rod bushing is gone that holds the shift rod to the bracket by the transmission, this allows for side to side movement at the shifter that does nothing at the transmission..makes it hard to find 1st.  The clutch slips bad, when shifting from first to second it nearly fails to grab at all if the vehicle speed is not matched up well.  There is pretty good chatter in first when taking off especially when hot.  The clutch parts we priced are not cheap, and with the guessed price of all needed bushings nearly make up half of the total.
Offline green1
« Reply #11 on: June 15, 2011, 09:17:56 PM »
Nick, Rick and Michelle have been very good to me and I am totally comfortable with what I was given as a fair estimate of the issues and the work to be done.  Rick has done several things for me already and I feel very comfortable taking any of our cars to him for repair.  It was never my intention to say anything derogatory about the price I was given - I hope Rick understands that.  I don't begrudge him making a profit while he's been fair to us.
It seems that today's weather is very appropriate for when it rains, it pours.  Timing on everything just sucks right now, but cars never have issues when it's convenient, do they?
  • Ooltewah
« Reply #12 on: June 15, 2011, 09:47:24 PM »
No problem at all!! Thanks for the kind words!
« Reply #13 on: June 15, 2011, 10:45:39 PM »
my bad, the, i think a 99 jetta is old stuff not used to seeing much of that anymore, have replaced many of the shift bushings in the past
« Reply #14 on: June 16, 2011, 12:44:40 AM »
I didn't want to sound cross. I just can't imagine spending so much for a repair! I guess thats why I like my old VWs!
Of course my in-laws just dropped over 3k into some repairs  :o
