Topic: Found the worlds cleanest burning engine  (Read 15801 times)
Re: Found the worlds cleanest burning engine
« Reply #60 on: July 27, 2012, 12:43:57 PM »
I'm new to this.  Is the Maytag engine a "hit and miss" engine?  I believe it's a 2 stroke . . . is it?  Most of the antique "hit and miss" engines I've looked at before are a whole lot bigger than the Maytag engines and they are typically 4 strokes.
The way I've always understood the typical "hit and miss" engine to work is that the intake valve is a spring loaded check valve . . . the only time it can open is when the piston is on the downstroke and the exhaust valve is closed.  The engine is governed by some type centrifical device.  That device will keep the exhaust valve open until the engine slows to specified RPM, then it will alow it to work off of a cam just like a regular 4 stroke engine.  If the exhaust valve is open, it doesn't create a vacuum on the downstroke, so the intake valve doesn't open, therefore no fuel goes into the cylinder . . . it just spins from the stored energy in the flywheel . . . once it slows to that minimum RPM, the exhaust valve closes on the downstroke, air/fuel is pulled in, then on the upstroke it is compressed, around TDC it is ignited by a spark plug and the power stroke speeds the engine back up.  The higher the load, the more combustion cycles you have.  The lighter the load, the less combustion cycles you have.
So, how close is what I think happens to what really happens? ???  And if a Maytag really is a 2 stroke, is it a hit and miss, or does it fire every revolution?
« Reply #61 on: July 27, 2012, 10:13:17 PM »
I can't look at eBay or Craigslist here at work, but I get off early today!  Come on 2:00!  I've got antique engines to shop for!   ;D
WOW , e-bay is eaten up with Maytag stuff. No excuse for not having a "jam up" engine.
I don't know . . . shopping for these engines is kind'a hit and miss. ;D
Perhaps the old fart can explain where the term hit and miss came from. I thought all you had to do was turn the key and EFI and computer modulated ignition made them run every time. I would think that if they missed continuously, you'd get a CEL?!?!
(I'm pitching some soft ones to the old man so that he will feel useful. I could have just googled it...)
I know what it means.  But "Back in your day" it either  explains Obozo's first term or what happens when you finish putting a engine together.
« Reply #62 on: July 27, 2012, 10:32:02 PM »
You pretty well nailed it. Yes the Maytag is a 2 stroke. Under a load they fire every revolution. Remember how the single cyl. 2 stroke motorcycles seem to skip a lick or two when idling and then fired every time when you took off. There is no governor on the 2 strokes like on 4 stroke "hit or miss" engine.
« Reply #63 on: July 30, 2012, 06:04:14 PM »
David, From what I've gathered in my short time of searching for a Maytag engine, the earliest engines were upright (cyliinder stood upright).  For the last two years of the uprights (around 1920,21) the upright engines used a quart mason jar for a gas tank.  The "Fruit Jar" engines are the rarest and most collectable of the Maytags because very few of them were built.  The fruit jar engines were replaced by a single cylinder that layed down.  Then they went to the opposed twin cylinder.
This one on Atlant's craigslist belonged to a "friend who passed away."  The seller doesn't seem to know too much about it.  Do you think this an early upright engine, or one that has been modified to look like one?  I've emailed for more pictures but haven't heard anything back yet.
 http://atlanta.craigslist.org/nat/atq/3166712189.html
« Reply #64 on: July 30, 2012, 07:14:09 PM »
I think this is an original vertical. Its not a fruit jar . The crankcase is sitting on the fuel tank. OK now a little history.  first washer 1909, first washer/ gas engine (vertical) 1911-1923 ,
Fruit Jar engine 1918-1919, First model 82 horiz single cly engine 1923-1927,  Model 92 horiz.single cly. 1927-1941,  Model 72 Style D- 2 cly 1937-1942,  Model 72-Style DA 2 cly 1942-1952.  NOW here is something to think about  .  About 1917 a fellow named H.L. Thompson( a friend of Fred Maytag) started to build his own version of the Maytag engine called Elgin RED-E-MOTOR. A "knock off of the Magtag vertical. Not a lot of history on this one, but I have seen one.
   The engine on craigslist looks very close to being a very early engine.  But it could be a RED-E-Motor. Lucky you if it is.
« Last Edit: July 30, 2012, 08:18:57 PM by Ret.Bugtech »
« Reply #65 on: July 30, 2012, 07:47:57 PM »
There you go Zen! Go pick it up
« Reply #66 on: July 30, 2012, 08:24:17 PM »
All this info came from my copy of C.H. Wendel " American Gasoline Engines since 1872"   Priceless now.
« Reply #67 on: August 05, 2012, 05:18:10 PM »
found one earlier today at the yardsales!  ;D ;D
« Reply #68 on: August 05, 2012, 07:47:54 PM »
Where was it and how much? Did you get the seller's contact info?    ???
Did you buy it?   8)
« Last Edit: August 05, 2012, 08:14:41 PM by Zen »
« Reply #69 on: August 05, 2012, 08:30:41 PM »
I didn't buy it; I couldn't afford it. And you'd do better to pay William to drive his big truck out to Colorado than to try to buy from that guy! He wanted $600 for it and it came with a whole set up with two wash bins and all. He said it ran last year at the yard sale and it pumped the pedal- it has compression. It was all there and very clean. He even had the electric motor for it. He was up on 157 down near the alabama line- he lives on the corner of the street my mom grew up on! If you want to go see it, take lots of cash and budget lots of time- he tells more stories than Zen!
« Reply #70 on: August 05, 2012, 08:48:40 PM »
I hit the sales on Signal Mt. yesterday.  Didn't see any antique waher related stuff except for a twin wash tub set-up.  The tubs were in decent shape but the stand had a lot of surface rust and one leg had been bent up and straighened out at some time in the past.  It had a price tag on it for $95.  A lady offered $85 and he took it just as I was walking up.  When I bought this washer at the auction, there was a twin wash tub set up that went for about that . . . I think it actually brought $95.
I still can't get a response from the guy in Atlanta with the upright Maytag.  Somewhere out there is one of these engines with my name on it . . . maybe someday I'll find it. 8)
« Reply #71 on: August 06, 2012, 01:24:36 PM »
« Reply #72 on: August 06, 2012, 04:57:02 PM »
« Reply #73 on: August 06, 2012, 06:04:21 PM »
Re: Re: Found the worlds cleanest burning engine
« Reply #74 on: September 13, 2012, 09:17:33 PM »
http://atlanta.craigslist.org/nat/bar/3186266374.html
This guy wants to trade a scooter for his hit and miss
