Topic: Ret. Bug Tech - knowledge  (Read 3898 times)
« on: July 30, 2004, 08:44:01 AM »
We have in our midst an individual and he may get mad at me for singing his praises here but I feel I need too.
In the past week I have learned more from him than you can imagine. For example, did you know the shaft in a Volkswagen distributor is supposed to have movement in the shaft so that when you turn the shaft a few degrees clockwise the rotor is supposed to return by itself back to the starting point freely? I didn't know that until the other day when Richard and I were working on his bus.
Did you know you can buy an out of the box progressive Weber carb and swap the jets and pretty much eliminate the common "flat spot".
I've started calling David "Godfather" and it sure fits.
When the "Godfather" speaks............everyone should listen. We can all benefit from this mans knowledge by just listening to him.
I hope we can set up some tech sessions soon and receive some of his knowledge.
        :cool:
« Reply #1 on: July 30, 2004, 11:13:13 AM »
OK Herby, Lighten up here. I do not ride around in the Pope-Mobile nor do I wear a big ring. The infomation is already out there in hundreds of articles/ books. The only things that are left out is the tricks of the trades and you only can learn these through experence. This is where I think I can help, but I don`t have all the answers,but I know where to look for it for the most part. All I`m trying to do is to make you think about what you are doing. If you are even slightly mech.minded its not hard to understand. If the old brain cells are not up to speed,this where I might be able to help you out. Its sorta like this: If you have a lock/key "thingy" going on, you don`t go to the barber shop, you go see Zen"the tumbler man". If you have a termite problem in the old car body,I`ll go talk to Richard seeing how he has been there,done that.Look at his super nice 69. Works for me. Bottom line: Please share tricks and info with your friends. Argue pro and cons on different things. Respect his/her opinions.  Remerber, "A man convinced against his will is of the same opinion still.
   (its David , Herby)
« Reply #2 on: August 02, 2004, 07:53:24 PM »
All of the above................Well put.   Thanks again, "David".
                                               :cool:
Offline eakanator
  • Rome, Ga
« Reply #3 on: August 05, 2004, 06:06:52 PM »
It doesn't matter, in these days when everyone charges a arm & leg to do things, most of the time your paying because of the knowledge that he or she has gained over the years.  I've only known you guys for a short time and all of you all have been great and I appreicate it. When you run across people who don't mind passing along the knowledge so that you'll increase yours, you never want to take it for granite because it's rare to get that for free or at least a reasonable price. I lift my mug and my other mug and my other mug.
Ron
« Reply #4 on: October 16, 2004, 03:58:14 PM »
Last night at the Sonic, I described a noise Homer had started making when I was letting off the clutch pedal.  Without hesitation, David told me what the problem was and what I would find when I pulled the engine out . . . rusty powder that used to be the pilot shaft needle bearing.  He heard it running and told me that I also had a loose head.
I was thinking the throw-out bearing was going out, but it was indeed the pilot bearing.  There was just a lot rusty powder and the remains of a couple of needles.  I suppose I would have figured that out while I had it apart, but I would have never guessed it had a loose head.  I thought I had an exhaust leak between the heater box and muffler . . . which I did, but it wasn't that bad.  I crawled under it before I pulled the engine and you could see where it was leaking and feel it, but you couldn't really hear it.  At least you couldn't here it over the compression leak between the head and cylinder.
 :salute:   Thanks David!  I've a 1200+ mile trip coming up in less than a month.  You probably just saved me from having to write a newsletter article about another one of my adventures!   :thumbs-up:
« Reply #5 on: October 17, 2004, 10:34:55 AM »
Zen, You are very welcome.  Even a blind pig can find an acorn if he has smelled them long enough. Im sorry that I may have ruined your chances to supply another great column for the news letter, but I bet you will come up with something. You and Homer The Super Bus are a lot of fun to be around. Lead on Macbeth!!!! \:D/
