Scenic City Volks Folks
Username   Password
May 26, 2013, 05:42:57 AM *
Pages: 1 [2] 3 4 ... 12
  Print
Author Topic: turbo diesel  (Read 6456 times)
Offline Offline
« Reply #15 on: January 08, 2012, 02:48:24 PM »
Another hose popped and I lost all my coolant again. I've identified the hose, just need to remove and replace. I wonder if there's a hose kit I could get to replace them all, cause I'm sure this won't be the last.
Ordered some aftermarket door handles too.
Offline Offline
« Reply #16 on: January 08, 2012, 05:23:12 PM »
I don't think this applies to your car Russ, but if you can't get the screw on the original handle to loosen on the passenger side, try tightening it.  My 96 Passat had left hand threads on the passenger side door handles.   Huh?
ASBug
Offline Offline
Varnel, Ga
« Reply #17 on: January 08, 2012, 09:33:20 PM »
You have a PM.
Thank me later...
Offline Offline
« Reply #18 on: January 12, 2012, 12:57:04 AM »
Got my hose in today and installed it. Now the thing won't start. I'm really not sure why just yet. Starter is new. I put some coolant in after putting the hose on and it cranked right up, I let it idle to circulate through the engine and then shut it off and went to the store for more coolant so I could fill it up all the way. Tried to start it after that and no go.
ASBug
Offline Offline
Varnel, Ga
« Reply #19 on: January 12, 2012, 09:44:04 AM »
Welcome to the 6 months of hell as you sort out your "new" car.
Good news is you are almos t 1/2 way through!
LOL,
Offline Offline
« Reply #20 on: January 12, 2012, 08:51:22 PM »
Had a bit of good luck tonight and traced the problem to the glow plug fuse, the little piece of wire was snapped in half. I was able to bypass it with a little piece of wire and it started right up. What an adventure this car is!
certdubtech
Offline Offline
In the Garage...
« Reply #21 on: January 12, 2012, 09:20:10 PM »
A real man woulda used a Juicy Fruit wrapper....   Wink    Cheesy
Good job, man!
Now hurry up and go drive it.   Cheesy Cheesy
travisyoung
Offline Offline
Redbank
« Reply #22 on: January 12, 2012, 10:03:15 PM »
I saw a myth busters where the hunter used a 22 bullet as a fuse
Offline Offline
« Reply #23 on: January 12, 2012, 11:21:43 PM »
Do remember the first time I met you ?   Herb and I came down to your house to check out your old Jetta. Do you remember what the problem was ? Wink
Offline Offline
« Reply #24 on: January 12, 2012, 11:30:56 PM »
I had forgotten all about that! It's a shame I couldn't hang on to that car. That's funny.
Offline Offline
« Reply #25 on: January 12, 2012, 11:35:40 PM »
Forgot to mention, I also got my new door handles. They are cheap aftermarket, but better than nothing, which is what I had on the driver's side. It looks good, but you still have to hold the handle in a bit when you pull on the latch to open. I guess no Mk2 door handles are any good.
Also, oddly enough my old key will open the new lock.
ASBug
Offline Offline
Varnel, Ga
« Reply #26 on: January 12, 2012, 11:54:47 PM »
Those look like the handles on the cabby.
Offline Offline
« Reply #27 on: January 13, 2012, 12:40:06 AM »
Also I need to address my turn signals. I think the switch is bad, when you push it down all the way (left or right) it just fizzles out, but when you hold it slightly in place the turn signals will work. The wiper switch is a little funny too. Sometimes when it's off it still runs the wipers, and sometimes when it's on the wipers will randomly quit.
While I'm remembering things, I seem to recall the wiper switch in my '89 Jetta breaking off in my hand one day while it was in the 'on' position. I had to turn off the wipers by pulling the relay.
Shouldn't be too difficult of a job to pull the steering wheel and replace the switches, I hope.
Offline Offline
« Reply #28 on: January 13, 2012, 08:34:47 PM »
Thanks to Rick I got that wire swapped out for a proper 50A fuse bar.
certdubtech
Offline Offline
In the Garage...
« Reply #29 on: January 13, 2012, 11:36:37 PM »
She's alive!!
Ha, saw it today... made me kinda miss my old '88 Jetta... man that was a fun car.   Smiley
Glad to be able to help.  Now drive that thing!
  Print
Jump to:
