Topic: Maintenance Tonight  (Read 9339 times)
Maintenance Tonight
« on: August 30, 2011, 06:45:38 PM »
Tonight around midnight the forums will be inaccessible for roughly 10 minutes while the site gets moved to a new host.
Re: Maintenance Tonight
« Reply #1 on: August 31, 2011, 01:01:12 AM »
Site is moved now. If you're reading this, then it worked!
« Reply #2 on: August 31, 2011, 10:29:46 AM »
Anyone notice any differences since the server move? Hopefully not, but on the plus side it does seem a little faster now.
« Reply #3 on: August 31, 2011, 10:31:34 AM »
Yep . . . seems a little faster to me!  Good Job (as usual) Russ!   ;D
« Reply #4 on: September 04, 2011, 10:15:16 AM »
Russ, The only thing different is now it takes two efforts to get on our web site. I can get on Fire-Fox and try to go to SCVF and it tells me it can't find the server. I close everything out ,put it sleep for about 15 sec try again and it pops right up for the rest of the day. I have to be in sleep mode for about 4 hrs and it will pull this trick. What the heck is going on ?
   D.J.
« Reply #5 on: September 04, 2011, 11:12:22 AM »
That's a strange one for sure. Have you tried shutting off the computer and turning it back on again?
« Reply #6 on: September 04, 2011, 02:30:52 PM »
Yes and it loaded just fine until I put it to SLEEP for 3-4 hrs.  and then it takes 2 times to load.  One other thing I find strange. Fire-Fox says I need to up-grade . I do what they tell me to do and comes back as a error. I did this for months. Now it tells me that my Mac system is not compatible after using it for 3 years. Whats up with that ?
« Reply #7 on: September 04, 2011, 03:43:54 PM »
You may just need to download a new copy of Firefox from http://www.firefox.com.
« Reply #8 on: September 04, 2011, 04:29:21 PM »
Been there done that many times.   No cigar .   You have to remember who you are dealing with Russ. I'm lucky if I  can turn this dang thing on.
« Reply #9 on: September 04, 2011, 04:46:14 PM »
Maybe I should come look at it. Have you tried the other browser, like Safari?
« Reply #10 on: September 04, 2011, 07:12:28 PM »
I started out with Safari with this Mac and only change to Fire-Fox when Hot mail got to be a real problem. I never had any problem with Safari except Hot-mail. I have Gmail now. I would give you a big hug if you could come by and untangle this mess
   Thanks Russ
« Reply #11 on: September 05, 2011, 10:48:21 AM »
I will see if I can get my valves adjusted first this morning on my coal truck. At this rate I may need a boat to get to your house
« Reply #12 on: September 05, 2011, 11:03:06 AM »
Thats what Boatswagens do in these trying times  ;)
« Reply #13 on: September 05, 2011, 02:27:11 PM »
With so much flooding right now I don't think it would be a good idea to try and drive. But I bet I can come out one night this week.
« Reply #14 on: September 05, 2011, 06:11:06 PM »
Sounds good to me ----Thanks
